30K Service
Old Mar 2, 2010 | 03:04 PM
'04 PWRSTROKE's Avatar
'04 PWRSTROKE
30K Service
My truck is creeping up on the 30K mark & it is time for oil change, trans service & fuel filters. I was just going to go to the dealer & they want approx $400 for all that. Anything special/unique I should ask for (synthetics etc...)? Or anything else that it may need? My truck is baby'd (very little towing or hard miles).
Thanks for your input.
Old Mar 2, 2010 | 03:35 PM
smlford's Avatar
smlford
I bring my truck in to the dealer every 30K to have them do all the services so that I have some paper trail with them.
I run synthetic and my truck seems to like it.
You have an '04 and you don't even have 30K on it yet?
Old Mar 2, 2010 | 04:27 PM
'04 PWRSTROKE
I told you it was baby'd...
Old Mar 2, 2010 | 05:15 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Wow mine just turned 140k. Do you "clean it out" every once in a while to keep the turbo freed up?
Old Mar 2, 2010 | 05:49 PM
'04 PWRSTROKE
If by "clean it out" you mean stomp on the go-pedal, I'll do that occasionally. I actually had to have the turbo rebuilt & the dealer said it was because the truck sat too much. I try to drive it at least every week now...
Still looking for anything special though I need to pay attn to at 30K besides what's mentioned above...
Old Mar 2, 2010 | 05:57 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Do you have a coolant filter system? CCV reroute? Fuel pressure gauge? These 3 things are important for longevity/PM. I'm sure there are a few others I'm forgetting. Synthetic oil is recommended, not mandatory though. Proper fluids, filters and fuel are a must, if you didn't already know.
Old Mar 2, 2010 | 05:59 PM
Jigger2020's Avatar
Jigger2020
when you service the tranny make sure they drop the pan & clean it out & put a new filter & pan gasket on it,ask to see the old parts just for the hell of it,tranny man, Gigger (I would run Ford ATF in there)
Old Mar 2, 2010 | 06:01 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Mercon SP or the new LV is recommended
EDIT: Maybe get the updated drain plug for the HFCM, unless you have done that also. Fumoto valve for the engine oil pan? ( for ease of OC)
Old Mar 2, 2010 | 06:32 PM
'04 PWRSTROKE
Thanks for the last 2 inputs...
I asked the dealer about the trans filter & they said the only filter is an external one (no pan gasket)... ? I read another thread that said to replace the filter o-ring too because of a potential leak.
How big of a project is a coolant filter system & CCV reroute? I'm assuing the fuel pump is prone to failure and that is why a fuel pressure guage is reccomended...? I do know it is not good to starve a diesel.
Old Mar 2, 2010 | 06:39 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
There are 2 tranny filters, internal and external. The internal is only good for filtering small logs, and is only "supposed" to be replaced at overhaul. However IIRC there is an 08-up internal filter that is a finer filter than the 03-07. Pan gasket IS reuseable. O-ring for external filter needs to be lubed prior to install, even then it might leak- mine did and I had to replace it. CCV is pretty easy, less than $15 in parts if you do the vent-to-atmosphere. Coolant filter- from dieselsite.com- is @ $120 and is highly recommended to filter out casting sand and debris from the block during the casting process. These write-ups can be found in the tech folder at the top of the forums page in red. https://www.ford-trucks.com/forums/3...ch-folder.html BTW, external filter housing is easily removed with an impact, a ratchet tends to seem like it wants to twist the housing off the framerail.
Old Mar 2, 2010 | 06:43 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
https://www.dieselsite.com/index.asp...ROD&ProdID=324 Heres the coolant filter kit I and alot of guys here have used
Old Mar 2, 2010 | 06:45 PM
utjer's Avatar
utjer
+1 for the diesel site kit. It took me about 40 mins to put it in. Very easy.
Old Mar 2, 2010 | 06:46 PM
Jigger2020's Avatar
Jigger2020
I have to admit I have been a retired Ford tranny man since 1995, I guess a few things have changed,I try,Gigger
Old Mar 2, 2010 | 07:04 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
You are right- it IS Ford ATF, but the Torqshift needs the Ford Mercon SP which is being replaced by Mercon LV Some guys have/ are using other fluid with success, but thats you're call. IIRC member DSMMH is using RP (?) and he isn't having any trouble with it. https://www.ford-trucks.com/forums/9...-problems.html
Old Mar 2, 2010 | 07:24 PM
'04 PWRSTROKE
Thanks for all the great info... Should help w/ long engine life; even at 5K miles/yr !
4x4fordtrkn
2004 - 2008 F150
20
Aug 21, 2015 09:00 AM
V10ZILLA
Modular V10 (6.8l)
Oct 13, 2010 07:13 PM
wreedZ71
2004 - 2008 F150
Mar 8, 2009 10:07 AM
Storm
Jan 11, 2007 06:21 PM
dexpy
Mar 18, 2005 08:28 PM
