Old Mar 10, 2010 | 03:31 PM
  #31
rat49f6's Avatar
rat49f6
Napa is $40 - $50 bucks for the filter
hd is $3 for the coupling (pvc)
pete is about $ 25 for his cover
equaling $ 68 - $78
or clay @ riff raff is $69 all included (metal connector)
Riffraff Diesel: RDP 6637 Filter Kit
Old Mar 10, 2010 | 03:38 PM
  #32
bluescrew's Avatar
bluescrew
how many inches of exhaust tubing will i need
Old Mar 10, 2010 | 03:39 PM
  #33
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
4" is plenty, but you can get away with 3". Don't forget the t-bolt clamp.
Old Mar 10, 2010 | 03:51 PM
  #34
A H DEVELOPMENT's Avatar
A H DEVELOPMENT
Thumbs up
Wow!! Nice of you to help out considering you might lose a customer.
Thanks Clay @ Riffraff.
Old Mar 10, 2010 | 11:05 PM
  #35
bluescrew's Avatar
bluescrew
thanks for the help. what should i do with the sensor that is in the air box..
Old Mar 10, 2010 | 11:46 PM
  #36
flatbeder's Avatar
flatbeder
I left mine under the filter pluged into the sensor. Haven't had a problem.
Old Mar 11, 2010 | 12:12 AM
  #37
bluescrew's Avatar
bluescrew
i guess ill try figure out how to strap it down
Old Mar 11, 2010 | 12:59 AM
  #38
flatbeder's Avatar
flatbeder
Strap what down the fiter stays put where the air filter box was. This is a really easy mod!
Old Mar 11, 2010 | 09:05 AM
  #39
superduty4x4's Avatar
superduty4x4
Zip tie it to the brake lines or somewhere convenient.
Old Mar 11, 2010 | 12:39 PM
  #40
A H DEVELOPMENT
Question Questions
Does the 6637 air filter upgrade perform as good as the kits with the heat shield? Concerned about pulling air in from under hood instead of through front grille area.
K&N Air Intakes, Cold Air Intakes - World Leader in Performance Air Intake Technology
Has anyone noticed if the Riffraff Performance 6637 pre-filter cover hender any air flow and does it lengthen the life of the air filter?
Any service departments @ Ford make a fuss about having this upgrade when in for service and trying to falsely blame other issues on it. When I was running a stock replacement K&N the diesel tech had some concerns about not using stock air filter. Also do you think they would have an issue with having that sensor out of place?
Thanks
Old Mar 11, 2010 | 12:49 PM
  #41
superduty4x4
Thanks
It will work just as good as an intake with a heat shield. If you are really worried about it, F350-6 has a good write up on building a heat shield.
The cover does not significantly hinder air flow, its mostly for looks but does offer some pre-filtering capability.
Who gives a **** what the mechanics at Ford say or think.
Oh, and search is your friend
Old Mar 11, 2010 | 01:06 PM
  #42
A H DEVELOPMENT
Service @ Stealership.
Yeah you see unfortunately I use Ford diesel techs to do all the service on my truck. You see the level of service I get there directly depends on how simple everything is, in other words if I go and start changing stuff around they are going to just focus on that one thing, if possible. This is the main reason why I have done any mods,well that & $$$, they love to blame stuff on other people and make up stuff. All the while they cant even perform a correct oil change!
I will do some FTE searching.
Old Mar 11, 2010 | 01:10 PM
  #43
superduty4x4
If they want to bitch about the 6637 let 'em. Its just as good as anything else out there. If you want something to keep the grease monkeys happy get the Ford AIS intake.
Old Mar 11, 2010 | 01:14 PM
  #44
A H DEVELOPMENT
Yeah I already looked at doing that, Stealership wanted $250 for parts.
Old Mar 16, 2010 | 12:24 PM
  #45
CobraGT40's Avatar
CobraGT40
I have a K&N Cold Air Intake and filter on my 2000 F250 7.3... I want to lose the K&N Filter asap, but want to keep the intake tube...will the 6637 work on the K&N tube ?
Thanks !
Scott
