Fog Lights
Old Mar 2, 2010 | 11:54 PM
tbear853's Avatar
tbear853
And there's no law requiring fog lights off with high beams on a two headlight system. You couldn't do it on a 4 headlight system in most states because then you'ld have 6 lights on at the front for general illumination at one time. Limit is 4.
Reason manufacturers set fog lamps to only come on with low beam even on a two headlamp system ... is because in fog, you want low beams on anyway to minimize reflected light bouncing back and blinding you. Fog is thinnest nearest the ground, which is why you see wide pattern fog lamps mounted ...
... low nearer the ground.
You take people who don't know better and sell them cars and trucks with fog lamps that come on with high beams and tell them they are fog lamps so they can see better in fog and they don't realise the high beams hurt them ...
... be preparred to be sued.
But for those who know fog lamps do help as long as low beams are used in fog, and who know to turn the high beams off in fog ...
... good mod for fill light along country roads with deer and bear and elk and moose!
Yep, good mod if used properly.
Old Mar 3, 2010 | 07:18 AM
the4by4freek's Avatar
the4by4freek
Ryan,
I did the relay mod not the switch. I was simply saying that mine has been this way for a LOOOOOONG time with no issues. It doesn't even take 12" of wire!
Old Mar 3, 2010 | 02:20 PM
Ryan50hrl's Avatar
Ryan50hrl
ahhhhh.....fair enough
Old Jun 6, 2010 | 02:36 PM
canblue's Avatar
canblue
Ford Xpress
Fog lights
If you already have the fog lights factory/dealer installed then the shorting of the relay is good. I had to add the lights and relay as the truck did not come with them.
For clarification.
Old Oct 23, 2010 | 07:54 PM
esnider225's Avatar
esnider225
speaking of driving lights .... 2005 f150 with factory driving lights. both drivers and passengers side show heavy condensation inside. my husband pulled them off today and found a large amount of water in each one. he's replaced a shattered bulb in one of them a while back. is there a way to take the protective cover off to reseal it to the housing? there are tabs top and bottom but we cant seem to get them to let loose. thank you for any help.
Old Oct 23, 2010 | 07:55 PM
esnider225's Avatar
esnider225
I have tried to search the site for some direction but couldnt find anything. any help?
TOMYO61
2009 - 2014 F150
Dec 15, 2012 06:24 PM
400Nut
May 20, 2012 02:25 PM
sanoe63
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Dec 29, 2007 10:53 PM
ForDen
Oct 6, 2002 07:09 PM
JPS
Feb 2, 2000 12:49 PM
