Offroad & 4x4
MSD OFF ROAD BOX
Old Mar 2, 2010 | 06:29 PM
alpha/omega's Avatar
alpha/omega
What all did you have wired up in there Rob?
I see the 6AL and the limiter window switch but what is that big box on the far right and is that a retard box (start I assume?) under the 6al?
Old Mar 2, 2010 | 07:06 PM
monsterbaby's Avatar
monsterbaby
to the right is the start retard box, directly under the box was a 2 step switch for use with the transbrake and the one to the right of that with the dial was a selectable rpm chip for selecting my launch rpm.
Old Mar 3, 2010 | 03:38 PM
kickingber's Avatar
kickingber
Thanks EVERYONE!
Thank you everyone for your advise,insight,and help. I really apperacite it. BIG TIME. I know that I want to upgrade my ignition (to bad I know very little about it.) What do you guys know and think about something called D.U.I. (Davis unified ignition) I found out about it lastnight looking around the net. from what I can tell it is the same as a chevy ignition, only more powerful and for a ford. It only has a 2 wire hook up.1 for the tach,and 1 for power. It will get rid of my stock ingition box,coil,and stock dizzy. The new dizzy,coil,and ingition will be all 1 pice. That is all I know about it. How do you guys feel about it? How does it compare to a Msd set up?
Old Mar 3, 2010 | 03:50 PM
alpha/omega
A DUI its a metric ***** ton better than a Pro Comp HEI but its pretty hard to beat a Duraspark distributor and a 6AL. Plenty of trucks in the 800+ range using the same setup.
Old Mar 3, 2010 | 09:57 PM
wayfastwhitey187's Avatar
wayfastwhitey187
thats all were runnin on our race trucks. the one with the most power has around 900 horses. duraspark distributer and 6al.
Old Mar 5, 2010 | 11:13 AM
Broncoholic1's Avatar
Broncoholic1
10X on the DS II & 6AL with rubber isolators 5 years so far,
Old Mar 5, 2010 | 11:44 AM
FordmanShane's Avatar
FordmanShane
sweet sounds great for mud drag-racing..
Hogtrapper
Mar 29, 2015 09:15 PM
grinnergetter
Nov 22, 2014 08:45 PM
TheKirbyMan
32
Aug 26, 2012 10:02 PM
WyoExplorer
24
Mar 17, 2010 09:42 PM
BigBronco93
Aug 16, 2001 07:37 AM
