exhaust advice needed asap!
thanks, im not so much concerned with the appearance of the tip as much as a good sound and above all performance. i dont want to run into having to go larger because of upgrades down the road. if the 4 inch is enough then so be it.
unfortunately i have a crew cab long bed so im sure ill be using all the pipe! lol! do you know if he has a kit set up with no muffler for cheaper?
You can buy the 4 or 5 inch system and buy the muffler delete pipe at an extra cost. To be honest, do the 4 or 5 inch WITH the muffler, theres not that much difference in sound and the muffler is a flow thru design so it flows. I have 4 inch duals with the muffler and its sounds sweet.
thanks for the advice guys. this is killing me! lol! i found another thread where everyone is behind the 5 inch kit! lol! i dont know what to do. i sure as heck dont want to do anything ill regret later. ok, so performance is not an issue, is there really alot of sound difference between the two? and can i get a delete pipe for the 5 inch if i decide to go that route?
My brother worked in a performance shop and dyno tested both 4 and 5" systems and found no difference in performance between the two.
Whatever you do, get the bellowed up pipe kit for sure.
The old style donut gasket up pipes are notorious for leaking and that costs in engine performance because you lose drive pressure for making turbo boost.
With the bellowed pipes, the exhaust is completely sealed and all the exhaust must exit through the turbo.
Clay, can you help the man out?
4" with muffler is plenty performance-wise and sound-wise. I love the sound of mine and minimal drone in the cab. Down side to 5": Cost -- 4" is usually cheaper. Fitment issues sometimes. And no gain over a 4" unless you're going for crazy HP levels (like 600+). If you're looking for an excuse to get the 5", you have a slightly different sound with it, looks, and you can say you have a 5" exhaust on FTE. That's about it.
Here's what my 4" MBRP with muffler sounds like:
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid370.photobucket.com/albums/oo148/Izzy351/Fuel%20System/FuelPressureDrop.flv">
I will keep the muffler when I upgrade because I like the sound better. I am going to the 5" for the look, there aren't any real performance reasons.
schnide
Exhaust Systems
02-28-2014 09:55 AM
jayro88
10-13-2012 08:59 PM
drtyhatch
12-06-2010 04:51 AM
