I'm Disappointed!!!
Old Mar 1, 2010 | 12:49 PM
CRICKEYDOG's Avatar
CRICKEYDOG
I'm Disappointed!!!
My 1996 7.3 with stock exhaust, no cat and a Magnaflow muffler had a beautiful sound with lot's of turbo whistle. I liked the whistle. I recently purchased a 1997 7.3. After removing the cat and adding a Magnaflow muffler, the sound is "ok" but I get no turbo whistle at all. None!!! Ford service say's she's making 16 PSI boost without being under a load so the turbo is working most good. Any idea's why I don't get any turbo whistle with my 1997 compared to the whistling Dixie 1996 I had previously??? TIA.
Truck on!!!
Old Mar 1, 2010 | 01:07 PM
DRRXR's Avatar
DRRXR
What kind of air intake is on it?
Old Mar 1, 2010 | 01:31 PM
CRICKEYDOG's Avatar
CRICKEYDOG
Both 1996 & 1997 have a stock air intake with stock Ford air filter's.
Truck on!!!
Old Mar 1, 2010 | 01:45 PM
foxracing0934's Avatar
foxracing0934
The only thing that I can think of is that maybe someone had swapped the exhaust housing on the 96 and instead of it having the stock a/r 1.15 it had a smaller one like a a/r 1.00 or 0.89. If this were the case then it would take less for the turbo to spool up on the 96 than on the 97, and thus you would in turn hear more whistle coming from the exhaust. Did you buy the 96 new or did someone ese own it before you? Oh and the 96 could have had an aftermarket down pipe which woul dhave added a lot to the whistling of the turbo, the stock one is a flat piece of srap metal and the aftermarket ones are 3" round pieces so there is much more air flow.
Old Mar 1, 2010 | 01:46 PM
DRRXR's Avatar
DRRXR
Install the 6637 mod get it from Riffraff contact Clay. Teh mod will make the difference. Pull the air inlet off of the one that is not making noise and check for dusting the turbo. Its edges should be sharp and should free spin. Dusting it easy to see in that everything will look dull. No play in or out or side to side.
Old Mar 1, 2010 | 01:48 PM
DRRXR's Avatar
DRRXR
EBV may also be stuck partially closed.
6637 mod
http://www.riffraffdiesel.com/mm5/me...e=FOBS-IN-6637
Old Mar 1, 2010 | 04:03 PM
MADVAN's Avatar
MADVAN
Ford is full of it. It cannot make boost under no load.
Check your peek boost first.
Bill
Old Mar 1, 2010 | 04:11 PM
WALJON's Avatar
WALJON
Bill
X2 they are full of it LMAO!
Old Mar 1, 2010 | 04:30 PM
DRRXR's Avatar
DRRXR
OT
Bill
Bill
Is his name FORD
Sorry for the OT he made me do it-------
Old Mar 1, 2010 | 04:35 PM
FARM69's Avatar
FARM69
Not to hi-jack the thread but does a turbo sound different once it's broke in?
It was finally above freezing with the sun shining yesterday and I had the windows down. My turbo seems to be louder than it was before. However, it's been months since I've had the windows down though...
Old Mar 1, 2010 | 04:55 PM
etldak's Avatar
etldak
The best I can get on the high way is 15 with my foot on the floor going about 75 80.with no load
DRRXR's Avatar
DRRXR
To FARM69
Its probably the air density and humidity thats making the difference or the windows open.
Old Mar 1, 2010 | 05:12 PM
FARM69's Avatar
FARM69
Originally Posted by DRRXR
To FARM69
Postmaster?
I was just curious as if the sound changes as the unit gets broke in. Not sure if this is the case for the OP though.
Old Mar 1, 2010 | 08:04 PM
Brown Falcon's Avatar
Brown Falcon
get a 6637 intake, 3" downpipe, and then you should hear more whistle...
Old Mar 2, 2010 | 10:00 AM
cowmilker08's Avatar
cowmilker08
Was the 96 a reg cab long bed or extended cab short bed and the 97 longer?
(extended cab long bed, crew cab short or long bed)
If so the difference in truck length and ultimately exhaust length could affect the exhaust sound the way you describe.
JBSIXGUNS
Aug 9, 2010 08:45 AM
kx450frider617
Mar 2, 2010 12:20 AM
RussB
Apr 5, 2008 12:13 AM
greatwhitef350
19
Jun 12, 2007 10:55 PM
davlan88
Feb 23, 2007 10:23 PM
