Trans slipping
Old Feb 28, 2010 | 04:44 PM
RhinoScores's Avatar
RhinoScores
Trans slipping
I have a '93 3.0 4x4 Ranger with a manual trans. Just yesterday, the trans started slipping - revs high and slowly begins to move. Just two weeks ago I had the clutch slave replaced and asked how the clutch looked - mechanic said it was in good shape. So if the clutch is ok, what could be causing such a problem?
Old Feb 28, 2010 | 05:16 PM
eigenvector's Avatar
eigenvector
Just a WAG, but maybe some air in the lines?
Old Feb 28, 2010 | 05:27 PM
Moto Mel's Avatar
Moto Mel
Check the bottom of the bell housing, if there is brake fluid there your slave is leaking and possibly spraying fluid onto the clutch and the shop that did the work needs to go back into it and do it right this time.
First check the fluid level in the clutch master cylinder.
The clutch should still be good but will need a serious cleaning with brake cleaner.
Old Feb 28, 2010 | 06:13 PM
RhinoScores
What's a WAG? The fluid level is fine.
Old Feb 28, 2010 | 07:18 PM
mfp4073's Avatar
mfp4073
Wild guess
and yeah, if someone worked on it a week ago, I would be suspect of the work first.
tj199700
Mar 8, 2015 03:14 PM
brucewon
Jan 9, 2013 09:41 AM
superduty4x4
Feb 10, 2012 11:44 PM
matpasch
Aug 20, 2009 04:05 AM
tranthac1
Apr 4, 2003 06:10 AM
