back window switch
Old Jan 21, 2003 | 01:15 PM
tempolraD's Avatar
tempolraD
Question back window switch
Hi all, it's been a while since i posted here. I used to be mightbgiant. anyway:
I think i might buy a 1994 f-150 to replace my 1988 f-150. The problem is that current truck has a sliding rear window and the new one does not, are they interchangeable? If so i would like to switch.
Thanks
Eric
Old Jan 21, 2003 | 01:30 PM
chuckman's Avatar
chuckman
back window switch
should pretty much swap right in, the only difference on the back of the cab should be the third brake light, which is avoided by the rear glass.
Old Jan 21, 2003 | 06:14 PM
83Steve's Avatar
83Steve
back window switch
I agree with Chuck - they'll swap '80-97.
Old Jan 21, 2003 | 10:09 PM
tempolraD's Avatar
tempolraD
back window switch
How hard would that be to do?
Eric
Old Jan 21, 2003 | 11:25 PM
83Steve's Avatar
83Steve
back window switch
Not very if you use some silicone spray lube on the rubber gaskets. Look in this album where I swapped the side windows in my Bronco - it's about the same. Click on the small pics to see the big version and read the captions:
http://www.webphotos.com/list_photos...&smi=1&a=13217
I traded a broken window out of a crew cab by myself in about 30 min, and it only took that long because it was raining on me.
Old Jan 24, 2003 | 01:20 AM
tempolraD's Avatar
tempolraD
back window switch
So there's no mechanical connection other than the rubber seal?
I just pry off the seal then let the silicone do it's job?
Eric
Old Jan 24, 2003 | 07:31 AM
steve83's Avatar
steve83
back window switch
I wouldn't really say "prying" - more like "working" it out. You start in a top corner pushing the glass outward, and lift the corner of the seal so it shifts a little with the glass. Then work your way along both sides from that corner lifting the lip and shifting the glass SLIGHTLY more outward each time. You don't want to bend the glass very much or it'll break - try to shift the whole pane by letting it follow that corner out. When you get the whole top edge & one end out, you can slide it sideways to get the other end out & then lift it out of the opening.
96f150
1997 - 2003 F150
Sep 28, 2015 07:30 PM
pllckjsh
2004 - 2008 F150
Aug 28, 2012 07:45 AM
paul1454
2004 - 2008 F150
Dec 17, 2011 09:12 AM
greg97
1997 - 2003 F150
Jan 22, 2007 10:43 PM
Mattdad1
1997 - 2003 F150
Aug 14, 2003 06:05 PM
