I have an 05 Ex and the wood grain insert on the console lid is pretty scratched up. Is it possible to replace just the insert or does would the whole lid need to be replaced?
if you have the new insert just glue it right over top the old one, Gigger, make sure you clean all the wax & armorall off with brake cleens or whatever so it will stick.
If it's like mine (2002 Limited) the woodgrain is not removable. In fact the whole lid is molded out of the wood grain plastic and the outside edge is painted to match the interior trim. Only way to fix it would be to find a woodgrain piece of vinyl wrap to put over the scratched center section.
They sell whole kits that will stick over it. You can get colored carbon fiber or several other textures. Just google woodgrain dash kits or carbon fiber kits. All you do is wipe it down with alcohol and peel and stick.
