Aerostar Ford Aerostar
Transmission Rage Sensor / Neutral Safety Switch??
Old Feb 27, 2010 | 05:20 PM
lpp71's Avatar
lpp71
Okay I have a 1996 Ford Aerostar Cargo. All of the sudden one day it wouldn't shift into reverse and D, 1, 2 is ONLY 1st gear will not go out of first gear. Neutral and Park of course function correctly.
I hooked up my Ford WDS Diagnostics computer and found that it gave a bad error for either Transmission Range Sesnor (Neutral Safety Switch) or linkage, and the linkage looks good.
Does this sound like the case, anytime a NSS went bad before on my cars it didn't shift out of park or other things.
Is it likely that OR is the transmission finally burnt up after 210k? Fluid looks ok.
Old Feb 27, 2010 | 10:08 PM
99f350sd's Avatar
99f350sd
In 96 they went to the all electric shift tranny. The Tranny range sw tells the computer what to do if its bad you may have issues.. They do fail its on the driverside...
2FordTrucks
Jun 19, 2022 08:29 PM
koplinhagen
May 24, 2015 02:25 PM
Scotty G
May 13, 2014 09:45 AM
iron1951
Feb 18, 2011 06:39 PM
CalebJns
May 9, 2010 10:03 AM
