fuel filter change big problem
Old Feb 27, 2010 | 04:47 PM
jwtimme's Avatar
jwtimme
I was having some problems with my 6.0 bucking at a slight acceleration form 50-60 mph wile tranny was in overdrive. It was time to change oil so I changed fuel filters too thinking this might help the problem. But now the truck misses at idle and bucks a lot from 45-65mph under acceleration and at steady throttle. Did I miss something when changing filters? I'm at a loss on this. Anybody have any ideas
The truck is an 07 automatic with 80,000 miles
Old Feb 27, 2010 | 05:02 PM
cheezit's Avatar
cheezit
you are still under 5/100 pay the $100 at the dealer.
Old Feb 27, 2010 | 05:42 PM
jwtimme's Avatar
jwtimme
was tring to keep the truck out of the dealer, use the truck for work With out the truck I loose money. I want to know if I did some thing wrong, I cycled the key a few times and it started right up but now it misses
I did some searching here and it looks like I might have an injector problem, so it looks like I will be with out the truck for a week.
Old Feb 27, 2010 | 05:44 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Have to tried to pull any codes? AutoZone (or most any big parts place will do it for free......
Old Feb 27, 2010 | 05:49 PM
69cj's Avatar
69cj
1. Did you use OEM filters?
2. Did you lube the O rings with oil? Not diesel fuel.
3. When the caps bottom out did you torque to spec?
Old Feb 27, 2010 | 05:53 PM
jwtimme's Avatar
jwtimme
used oem filters, lubed with oil, did not torque don't have a socket that big
Old Feb 27, 2010 | 06:01 PM
69cj's Avatar
69cj
Possible you could be sucking air. Take cap off the top filter and see if it is full of fuel. If not have someone do key on and see if it fills without sucking air. ie; air bubbles.
Old Feb 27, 2010 | 07:21 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Sounds like a hairline crack in one of the caps on the fuel filters. Have to remember fuel molecules are larger than air molecules. If not cracked - then as stated take it in as we are guessing.
jenn o
1983 - 2012 Ranger & B-Series
Jan 28, 2011 09:26 AM
maxxf150
1997 - 2003 F150
Jan 1, 2010 11:05 AM
jncrgsc1
Mar 17, 2007 10:02 PM
MemOrex
Nov 10, 2005 12:05 AM
wgpoarch
Nov 30, 2003 11:31 AM
