68 merc problem
Old Feb 27, 2010 | 01:22 PM
mercman67's Avatar
mercman67
68 merc problem
hey there, i have a 68 m100 with a 360, and 4spd, when i just recently tried to start it the solenoid started to click very loudly, at first i thought it was just a dead battery so i boosted it and it stated fine i let it idle for about 20 min and shut it off and tried to start it again and all i got was the same loud clicking from the solenoid. My question is would this be the voltage regulator causing this, or is something wrong with the alternator? any info would be great thanks.
Old Feb 27, 2010 | 05:15 PM
jowilker's Avatar
jowilker
Your battery could be gone and is not chargeable. If it will crank with a boost leads me to think battery.
Parts stores in the south will test your battery for free. Just don't shut it off or drive it at night till you figure it out.
John
Old Feb 27, 2010 | 06:42 PM
montana_highboy's Avatar
montana_highboy
Check that your battery/starter cable connections are clean and tight.
Old Feb 27, 2010 | 08:00 PM
Ford_Six's Avatar
Ford_Six
Check your voltage with the engine running. It should be around 13.5. If it's not, then chances are the alternator or voltage regulator is about done. It could also be the fusible link between the alternator and solenoid, but that's not overly common without some large overload.
corbit96
Sep 16, 2014 06:56 PM
F-250 restorer
Jun 1, 2014 09:24 PM
Kapusta
May 26, 2014 09:44 PM
flashback max
1997 - 2003 F150
Oct 29, 2013 12:25 AM
Holiver31
Oct 13, 2009 12:00 AM
