I went out to run an errand, got into my 2005, 5.4 F-150 with 23500 miles on it.
Engine turns over but doesn't start. Is there anything to check before I call a tow?
I have just returned from a 700 mile trip, the truck performed fawlessly, parked it in the garage and now it will not start.
Any suggestions? Has 1/2 tank of gas.
When you turn the key to on(not start)can you here the fuel pump make a noise.The pump will only make the sound for approx 1-2 seconds.If no sound happens the fuel pump driver module has shorted out.This problem is common on all f150 that are driven in winter conditions were there is road salt.
