hard starting 360
Old Mar 22, 2005 | 07:24 PM
green52's Avatar
green52
hard starting 360
I 've got a 76 f150, It starts fine if the the engine is stone cold or if it's completly warmed up, but anything in between and it doesn't want to start. It turns over but won't start. If I'm lucky cranking on it for about 5 min it might sputter to life. any ideas?
Old Mar 22, 2005 | 09:06 PM
76supercab2's Avatar
76supercab2
My guess would be choke is not properly adjusted. Hard to tell from your description if it's comming off to fast or not fast enough.
Old Mar 22, 2005 | 09:26 PM
ford390gashog's Avatar
ford390gashog
sounds like it is flooded like the choke is not working or you could have a bad ignition box
green52's Avatar
green52
It's got a holly 2300 with a manual choke. could i not be adjusting the choke right? When I can't start it I try every choke position and still nothing.
tperk100
Nov 1, 2011 05:17 PM
Fox Fader
1997 - 2003 F150
Mar 1, 2011 03:00 PM
Rob73
Aug 11, 2003 11:49 PM
Bsambear
Aug 5, 2003 03:13 AM
