A/C System Pressures
Old Feb 27, 2010 | 12:16 PM
janton01's Avatar
janton01
Will be purging and re servicing the a/c in my F250 once it warms up enough around here. Does anyone have a reference for the system pressures. Thanks.
jerry
Old Feb 27, 2010 | 12:19 PM
69cj's Avatar
69cj
Just google it. They will have press. charts that show for amb. temp vrs. humidity. Select the proper freon chart, 134A, and hook your gauges. If you empty the system you need to vacum it down to 28 inches of water for 1 hour to boil off any moisture in the system. Why are you going to"purge the system" Strange terminology.
Old Feb 27, 2010 | 01:02 PM
janton01's Avatar
janton01
Sys has a very slow leak in it so I will empty it then replace and tighten up all the seals and joints. I also want to insure that the correct amount of oil is in there. Have the vac pump and gauge manifold but want to get the r134 charts to insure the correct fill pressure and quantity.
Old Feb 27, 2010 | 01:15 PM
69cj's Avatar
69cj
While you have the system open you might want to replace the orifice tube. It's like tuning the system up if it has any blockage. Under 10 bucks at most parts stores. A common place for these systems to have a slow leak is the schraeder valves. Cheap to replace while the system is open.
Old Feb 27, 2010 | 06:47 PM
janton01's Avatar
janton01
Thanks for the tip, I will make a point of replacing each of those items. Well worth the effort in the long run.
firebug
Jul 31, 2011 08:51 PM
Topdog64
2004 - 2008 F150
Mar 19, 2011 02:59 PM
firepop5
Jun 21, 2009 02:47 PM
Opossum
Nov 16, 2008 09:33 PM
dunebuggys
Jul 8, 2000 10:09 PM
