a/c pressure
Old Jul 31, 2011 | 05:49 PM
firebug's Avatar
firebug
a/c pressure
What pressure do I need to fill a/c system to.
Old Jul 31, 2011 | 07:18 PM
Epd444's Avatar
Epd444
Charge it by weight. I forget how much these trucks hold but theres a sticker under the hood where the belt diagram is, that should tell you the wieght.
Old Jul 31, 2011 | 07:25 PM
fordpride's Avatar
fordpride
That only works if the system in completely empty
Old Jul 31, 2011 | 07:50 PM
Action4478's Avatar
Action4478
Or if you have a scale ...
Old Jul 31, 2011 | 08:24 PM
DRRXR's Avatar
DRRXR
If its a simple recharge - Best I can remember is to add until you reach 43 pounds or near that on the line pressure and the can is no longer getting cold. That works for the Hoston temps at this time of yr.
Normally its close or just under 2 pounds empty
Old Jul 31, 2011 | 08:32 PM
Midwest Dually's Avatar
Midwest Dually
Right on the money! 35-45psi with an outside ambient temperature around 90 degrees!
Old Jul 31, 2011 | 08:51 PM
fordpride's Avatar
fordpride
What I was getting at is if the system still has a half pound in and you add the lbs that the system calls for then it will be over filled by a half pound
bismic
Aug 26, 2011 08:53 PM
ford4x4956
Jul 1, 2010 09:50 PM
hwm3
Jul 16, 2009 10:34 PM
Opossum
Nov 16, 2008 09:33 PM
76 F250 4X4
Nov 27, 2004 01:20 PM
