axel rebuild
Old Feb 27, 2010 | 09:05 AM
bill1187's Avatar
bill1187
axel rebuild
has anyone ever had there axal rebuilt my clutches are slipping bad i was just wondering what this would cost
Old Feb 27, 2010 | 09:51 AM
cps's Avatar
cps
Go to Randys Ring $ Pinion web site and you will get an idea of different options you can go with regarding your rear end. I personally would not rebuild the LS rear end and would with an ARB locker or a detroit locker or one of the other after market brands.
Old Feb 27, 2010 | 11:00 AM
mueckster's Avatar
mueckster
My truck didn't come with a LS rear differential. I weighed the options and went with the Truetrac "clutchless" (helical cut gears) diff. It has been working great and is reasonably priced compared to the "clutch" type. It requires no maintenance, other than the routine gear oil changes, with no additives needed.
Old Feb 27, 2010 | 12:20 PM
tsmall07's Avatar
tsmall07
What axle do we have in the rear? Is it the same for DRW and SRW?
In a related story...
Do I need a regular kingpin dana 60 axle nut socket to get the front hubs off or is it different on this truck?
Old Feb 27, 2010 | 12:27 PM
mueckster's Avatar
mueckster
SRW has the Ford/Sterling 10.5" diff and the DRW has the Dana 80.
Not sure about the socket. I have one with a pilot tube in the middle of the socket that fits into the spindle of the rear axle.
Old Feb 27, 2010 | 03:22 PM
PaysonPSD's Avatar
PaysonPSD
No special socket for the front hubs. Info LINK
Old Feb 27, 2010 | 07:44 PM
SpringerPop's Avatar
SpringerPop
Nope. Nothing special.
Needle-nose pliers and a snap-ring pliers is helpful.
Pop
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
