Turbo Vane Control Question
Old Feb 26, 2010 | 11:40 PM
dirtleg's Avatar
dirtleg
I have a spare 6.0 turbo that I am wanting to use on another project. What I need to know is what type of signal is used to actuate the solenoid for the spool valve to control the vane position?
Thanks.
Old Feb 26, 2010 | 11:47 PM
bismic's Avatar
bismic
This may or may not be what you are looking for ....
The turbo has a set of moveable vanes in the turbine housing that change the flow of the exhaust through the turbo. These vanes are internal to the turbine housing and are mounted around the outside circumference of the housing.
Changing vane position either restricts or increases the amount of exhaust gases allowed into the turbine housing. Each individual vane has a tab on it that attaches to a ring linking all the vanes together. When the ring is moved, all of the vanes move a corresponding amount.
A linear actuator attaches to the ring. Actuator position is changed by varying the amount of pressurized engine oil applied to either side of the actuator. The flow and placement of the oil is controlled by the VGT solenoid which is in turn controlled by the PCM.
The VGT solenoid is a pulse width modulated (PWM) solenoid. Increasing the current duty cycle to the VGT solenoid increases boost.
The solenoid routes oil to one side of the linear actuator forcing the actuator to move, which in turn moves the ring linking the vanes.
The vanes move to an open position allowing more exhaust gases into the turbine housing. More exhaust flow increases turbine speed with a resultant increase in boost.
The converse is also true. When the current duty cycle is decreased, boost levels also decrease.
The PCM monitors a variety of sensors to determine how to duty cycle the VGT solenoid.
In closed loop, the PCM uses exhaust backpressure, manifold and barometric pressures, accelerator pedal position, and engine RPM and calculated load for turbo control.
Changes in parameters for each of these sensors will result in a variation in VGT duty cycle. Higher load demands more duty cycle.
This is how the PCM controls the turbo boost to match engine load and requirements.
Old Feb 27, 2010 | 12:27 AM
william_04_x's Avatar
william_04_x
Do you have an oil supply for it? Click..
Old Feb 27, 2010 | 09:35 AM
cheezit's Avatar
cheezit
to sum up the question the vgt is 12v and is duty cycled
Old Feb 27, 2010 | 11:58 AM
steelhead2's Avatar
steelhead2
bismic, is there anything you don't know about the 6.0?.nice explanation
Old Feb 27, 2010 | 02:34 PM
bismic's Avatar
bismic
It's all about the Holiday Inn Express .........
Seriously though - the real pro's here are the Techs. Many thanks to those that have taught us and continue to do so!
Old Feb 27, 2010 | 06:49 PM
dirtleg's Avatar
dirtleg
Thanks for the replies. One question answered. One new question realized.
Bismic thank you for the detailed explanation.
My thought was that I could use a programmable controller to read signals from the TPS, rpm, boost, vehicle speed, and EGT's and with some trial and error program it to work on my intended project. Knowing that it uses a 12v PWM signal makes it so much easier.
As far as oil to actuate the vanes what is the necessary operating pressure of the spool valve? I could easily rig up an electric or engine driven pump to generate the necessary pressure if engine pressure is not sufficient.
Again thanks.
Old Feb 27, 2010 | 08:31 PM
cheezit's Avatar
cheezit
the oil pressure required is only base oil pressure and at 40-60 psi would bea good place to be. I would aim for the middle ground.
Old Feb 28, 2010 | 06:52 AM
Subsailor1127's Avatar
Subsailor1127
OK, I have to ask....what is the new project? Sounds like fun!
Will Bite
May 16, 2017 08:18 AM
Simps
Mar 17, 2017 08:37 PM
WatsonR
Mar 11, 2016 05:15 PM
Bullitt390
Mar 3, 2015 03:00 PM
Bobcat7
Jun 17, 2007 10:45 PM
