E4OD to Manual
Old Jan 21, 2003 | 07:02 AM
Will Stewart's Avatar
Will Stewart
Question E4OD to Manual
I know a lot of people ask but here we go again. What is involved in the swap and how much do i have to change. I was thinking about the zf tranny but would also like to here suggestions on tranny selection.
The truck is a 95 f250, 351w on its 4th E4OD and soon ready for its 5th. Got to go manual! The dealer's service dept. says its because is of the larger tires (I went to 255/85/r16, which are 34 in high) But these tires are only two inches greater than the stock 235's which are 32 in high.
The truck is used for snowplowing and for towing a gooseneck trailer.
Old Feb 5, 2003 | 01:52 AM
sGreuel's Avatar
sGreuel
E4OD to Manual
Will,
I've got a 93 f350 diesel crew 4x4 with the A4OD, and I've been considering that same solution.
Every so often on a high speed drive down the interstate in the summer,(with and without heavy trailer loads) I seem to blow out from half to 3/4ths of my trans fluid. The last time a kept driving too long, and after refilling, the front seal now leaks regularly. That seems to be where it was blowing out while it was hot the previous times.
Also, without a manual trans, this nonturbo diesel just seems to be week, Especially after getting out of a 390 or 460 truck.
Good luck, let me know what you hear, s
Old Feb 5, 2003 | 08:29 AM
steve83's Avatar
steve83
E4OD to Manual
Have you or the dealership reset the speedometer? That'll kill an electronic transmission with non-OE-size tires.
Old Nov 16, 2006 | 06:38 PM
sGreuel's Avatar
sGreuel
So how do you reset the speedometer?
E4OD correction from above A4OD.
Cantfinditgrindit
23
Jul 26, 2016 06:47 AM
wahlturfcare
37
Jun 18, 2016 01:44 PM
ponticelli1221
May 20, 2015 08:59 PM
nicksorenson
Oct 8, 2009 06:25 AM
Tall Paul
All Things Towing
Jul 19, 2000 10:00 PM
