Door Lock Actuator
Old Mar 2, 2010 | 04:19 PM
  #31
Billyclub's Avatar
Billyclub
I remember reading about this happening to someone else. In the end he disconnected the batteries and that reset the computer thing-a-ma-bob and that took care of it.
hope it works for you.
glenn
Old Mar 2, 2010 | 05:06 PM
  #32
binuya's Avatar
binuya
Originally Posted by krejci.mike
I did this mod a few weeks ago but my drivers side is backwards (locks when you hit unlock and unlocks when you hit lock). How do I fix this?
I believe you'll need to take the actuator apart again, take the white plastic end piece (of the motor which held the foil wrapped repair), and spin it 180 degrees. Pretty sure that should restore it to correct phase.
Old Mar 2, 2010 | 11:06 PM
  #33
krejci.mike's Avatar
krejci.mike
OK thanks.
Old Mar 7, 2010 | 04:55 PM
  #34
Skip1970's Avatar
Skip1970
took door panel off today! wow lots going on in that little space, debating on retaking it off next friday so i have all weekend to get it back togeather!! also thinking if i should oprder them new actuator from this place Ford Excursion Power Door Lock Actuator at 1AAuto.com or just try the repair like has been done by others..
choices choices!
Old Mar 7, 2010 | 05:59 PM
  #35
Fishin76's Avatar
Fishin76
Yep, that will fix it. The end of the motor techically should fit only one way, If you have it wrong, their will be a open space on one side.
Old Mar 7, 2010 | 06:04 PM
  #36
Fishin76's Avatar
Fishin76
choices choices!
I thought it was bad at first too, but then I took off the inside and outside door handles and realized that there was lots of room inside that door panel. I can get my arms to anywhere in that door, and manuver tools and parts. Try this on a compact car! can't hardly get a hand inside to feel a thing.
Old Mar 7, 2010 | 10:48 PM
  #37
Skip1970's Avatar
Skip1970
alright whos got pics the how to repair the inside of the door lock motor, i cant find any, and is it just taking house wire copper and soldering it into where some resistor went?
Old Mar 7, 2010 | 11:18 PM
  #38
binuya's Avatar
binuya
Here's the link: https://www.ford-trucks.com/forums/4...cks-fixed.html
(Pics are on the second page of the thread.)
All you need is a tiny piece of foil and a means to re-secure the actuator. I did it with zip ties.
Old Mar 7, 2010 | 11:28 PM
  #39
Skip1970's Avatar
Skip1970
Thank you very much!
Old Mar 7, 2010 | 11:56 PM
  #40
binuya's Avatar
binuya
You're welcome. Once you do one, the rest will go way quicker. I did mine a bit over a year ago and they're still working strong. Not bad for a significant fix that cost nothing but my time.
Old Mar 14, 2010 | 08:43 PM
  #41
Skip1970's Avatar
Skip1970
oh no a metal rod is dangling from the unit i pulled out! i dont know where it goes. getting worried..drivers front door.. hekp please..
heres a picture
Old Mar 14, 2010 | 09:07 PM
  #42
Fishin76's Avatar
Fishin76
The light green connector on the bottom right of the pic, thats where the small end of that rod goes, I believe.
Old Mar 14, 2010 | 09:34 PM
  #43
binuya's Avatar
binuya
heres a picture
Uh oh. I believe that is correct that the small end goes into the green clip. But you might have to pull passenger door panel off to look at orientation. Unfortunately I don't have any pics. Good luck, and let us know how it turns out.
Old Mar 14, 2010 | 10:17 PM
  #44
Skip1970's Avatar
Skip1970
Mission accomplished! just like george bush! that rod went in the first thing you pry apart the plastic jaws! all togeather and works like a charm! thank you guys! heres some pics, man all i want to ever own is fords because of the people on FTE. FTE+FORD = LOVE.
thanks guys!
motor before fix
after fix tinfoil
all togeather case
and actuator ondoor mechanism, i superglued the seam and the pins i didnt drill out, the 2 i drilled out i put bolts and nuts thru.
heres inside the actuator incase anyone needed it for reference
Old Mar 14, 2010 | 10:25 PM
  #45
snakedoc's Avatar
snakedoc
i did my back right door and now it works like new, i did not put blots in it i used very small wood screws to hold it together. thanks for the info.
