Offroad & 4x4
Simple Lift Question
Old Feb 26, 2010 | 02:05 AM
jamestw1977's Avatar
jamestw1977
O.k. here's a good simple lift question. I have a '78 f150 supercab longbed 4x4 All I want to know is with a 4 inch lift is there anything other than installing the new leafs, and shocks along with a drop pitman arm necessary. Does anybody know if the pinion angle is ok with this minimal lift? Realistically all I wanna be able to do is fit some nice beefy 35's under it. I use this truck everyday for work and play so. I'm not wanting to spend a ton of money on crap I don't need.
Old Feb 26, 2010 | 02:20 AM
captain p4's Avatar
captain p4
Shouldn't need anything else. Maybe extended brake lines if you're going with a super flexy suspension, but I doubt it... most likely they can be rerouted either way. The supercab f150s come with leaves up front, right? If not you'll need things to correct the radius arm geometry.
Old Feb 26, 2010 | 08:09 AM
Carlene's Avatar
Carlene
Admom
Hi James. Welcome to FTE.
Hope you don't mind but I put your post and Paul's reply as a seperate thread so it doesn't get lost in that other Lift? thread.
I tried to contact you privately but you have all contact methods turned off.
Old Feb 26, 2010 | 06:54 PM
alpha/omega's Avatar
alpha/omega
The SC F150s are leaf spring fronts and use F250/350 springs.
Springs, shocks, a pitman arm and possibly brake lines, as Paul said, is all that is necessary.
Old Feb 27, 2010 | 12:20 AM
jamestw1977
Hey no problem. I was actually kind wondering about that after I read through all that stuff, and posted.
Yea it's leafs up front. I had somebody that had a dent side tell me thats all I would need to do because "that's all I did" so I just wanted to make sure before I started tearing things apart.
Old Feb 27, 2010 | 07:13 AM
alpha/omega
I think you'll be fine.
Some pics of the rebuild would be nice along with discussion of any problems or tricks you come across.
kammrk
Oct 16, 2016 11:37 PM
d_mcphail
Aug 23, 2013 02:53 PM
warnecke13
13
Jan 18, 2012 11:27 PM
cmcostan
Oct 27, 2010 12:31 PM
ford_mudd_runner
Offroad & 4x4
34
Jun 18, 2005 02:29 PM
