Offroad & 4x4
Lift?
Old Feb 25, 2010 | 02:00 PM
bogger1966's Avatar
bogger1966
Lift?
Im trying to fit some 44" boggers on my 91 f150, how much lift do i need to do this and what kit should i buy, im also considering a body lift, what is the best one out there?
can i just use blocks for the rear and keep the stock springs?
thanks....
Old Feb 25, 2010 | 02:03 PM
captain p4's Avatar
captain p4
Depends on how much fender trimming you want to do.
But the main issue here is your half ton drive train, which won't hold up to anything bigger than 35s for any substantial amount of time or abuse. Do you plan on upgrading you're axles? gears? motor? It takes a lot of money to put 44's on a truck the right way, and body lifts and blocks is not the right way to do it.
Old Feb 25, 2010 | 02:06 PM
bogger1966's Avatar
bogger1966
im going to keep the stock axles.....my buddy has almost the same truck with 44's on his and hasn't broken anything and he beats the hell out of it.
i'll prob. put some 4.56 gears and im thinking about dropping in a 460 for power.
can you suggest a kit to do this? im new to this kinda thing.
Old Feb 25, 2010 | 02:08 PM
bogger1966's Avatar
bogger1966
oh, and i dont want to cut the fenders i want enough lift to clear them.
Old Feb 25, 2010 | 02:18 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
Runs 44"s with a 302 and half ton axles....
Quite possible.
a 460 will snap your axle's like a twig...
4.56 gears wont be enough.
Old Feb 25, 2010 | 02:35 PM
kjett's Avatar
kjett
Quite possible.
Don't waste your time Don. People like this think "beating the hell" out a truck with 1/2 ton axles and 44's are talking about climbing the speed bumps at the local mall.
But on a serious note, 4.56's would be overkill for 44's. Somewhere around 2.80- to as low as 3.55 would be perfect and get somewhere in the neighborhood of 17-19 mpg.
Old Feb 25, 2010 | 02:50 PM
Truckin4life
Truffcupcakes
Hey, i take my truck to the mall, quite often, happens to be that the mall also shares a parking lot with home depot...
My truck would probably break if i tried to crawl over a speed bump, man thats a little to extreme for me...
Old Feb 25, 2010 | 03:19 PM
captain p4's Avatar
captain p4
I'll leave my helpful and PC response for any crazy newb with similar ideas that happens to search.
Old Feb 25, 2010 | 03:31 PM
Truckin4life
Newbs searching is auto rep in my book...
kjett's Avatar
kjett
I did see a ranger running around here with 44's and the stock axles. He had a 302 swap in it and flogged it off road quite a bit, so the D44 ttb should be fine for your needs. As for the rear, if you can't get new springs, try looking for some interlocking bricks. They work in a pinch
Now for the body lift, they can be quite expensive, so head down to your local sporting good store and get a bag of hockey pucks. Stack 3 together by using some gorilla glue, then drill the center for a longer body bolt. If you are anywhere near Florida, theirs some douchebag down there with a big underpowered lawn orniment that has a body lift he might be pulling off his, so you can see if he'll sell it to you cheap.
Old Feb 25, 2010 | 05:46 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
thanks....
I see what you did there.
Old Feb 25, 2010 | 05:50 PM
captain p4's Avatar
captain p4
Old Feb 25, 2010 | 05:51 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
WOW.......this is gonna be funny
Old Feb 25, 2010 | 05:54 PM
bogger1966's Avatar
bogger1966
Quite possible.
ive seen dana 44's hold up to a bunch....
why wont 4.56 gears be enough? I should be running about 600 horsepower
Old Feb 25, 2010 | 06:00 PM
bogger1966's Avatar
bogger1966
double post
