help - fogging windows
Old Feb 27, 2010 | 01:57 PM
wminmi's Avatar
wminmi
got my core out today....not too bad
Was a pinhole in the core though, and I doubt the mouse nest and acorn shells didn't help matters any LOL
Did notice I don't have a drain at all, completely solid housing......
And of course NOBODY has the hi-output heater core in stock, get to order that Monday it appears. Not even NAPA online, website says it HAS to be ordered through the local store
Old Feb 27, 2010 | 03:56 PM
dyoungen's Avatar
dyoungen
What's the differance between the high output and regular? I asked at the NAPA I bought mine from and he said he didn't know and had never ordered one. Mine is the regular output and is doing fine even with the temp in the single digits.
Old Feb 27, 2010 | 04:04 PM
DRRXR's Avatar
DRRXR
You think you could cut out the fins clean it and solder it up? Just a Q but you are probalby like me and wont to fix it once.
Old Feb 27, 2010 | 07:38 PM
dyoungen's Avatar
dyoungen
If you go thru the hassle of fixing it you will most likely end up fixing it again. The metal is so thin that when you weld or solder it you will weaken the surronding area. Years ago that's what we did but now any more.
Old Feb 27, 2010 | 07:57 PM
wminmi's Avatar
wminmi
The only differences I saw between the standard and the hi-output was the sizing. The "standard" was a tad smaller.
The thought had crossed my mind to solder it up, but I thought the same thing: weakining the surrounding metal. Better off just to replace it and call it a day
Old Feb 27, 2010 | 08:41 PM
WarOzz's Avatar
WarOzz
Without a boiler tank you would never be able to get it clean enough to solder up and hold. For the low cost a replacement is worth the wait.
Scruffy
Apr 20, 2009 05:08 AM
BajaRacer909
1997 - 2003 F150
Nov 16, 2005 01:37 PM
exiled
2004 - 2008 F150
20
Sep 13, 2005 01:23 AM
YOMAN
2004 - 2008 F150
15
Mar 4, 2005 09:46 PM
shotgunner426
Oct 3, 2003 04:06 PM
