87 f150 payload
Old Jan 20, 2003 | 11:59 PM
FiveO's Avatar
FiveO
87 f150 payload
What is the payload rating for an 87 f150? specifically singlecab longbed 2x4
Old Jan 21, 2003 | 05:34 PM
Supercab's Avatar
Supercab
87 f150 payload
It depends on YOUR truck's warranty plate on the drivers side door jamb.
It should show you the MAX GVW, and also show the MAX for front and rear separately, you can get an idea of your payload by checking your registration weight, and your waranty plate, your registration weight should be close to what your truck weighs empty.
Old Jan 21, 2003 | 06:27 PM
83Steve's Avatar
83Steve
87 f150 payload
You can see your particular truck's actual reserve capacity (the amount the axles can carry over the weight of the truck) on the door jamb sticker straight across from the VIN number inside a thin L-shaped line. There's a number following an F for the front axle reserve, and another following an R for the rear. That's the GAWR minus the actual weight your truck puts on that axle, leaving you with the available cargo weight.
Of course, the truck can actually carry MUCH more than that safely...
Old Jan 21, 2003 | 10:14 PM
FiveO's Avatar
FiveO
87 f150 payload
alright ill check that out. i think i had a little too much weight in it at one time. loaded the whole thing full of wood. it was stacked so high that i had to put a piece of plywood along the side of the bed so i could fit more wood. it almost looked like i had a low rider with big tires.
Old Jan 22, 2003 | 11:17 AM
Darin Bell's Avatar
Darin Bell
Smile 87 f150 payload
First find out the GVWR on your truck. Then go fill up your truck with fuel and go down to a public scale and weight the truck with you in it. Subtract the scale weight from your GVWR and that is your payload.
Darin Bell
shedhorns
2009 - 2014 F150
Feb 20, 2017 01:04 PM
Ford Trucks
Official Ford Forum : Ask an Engineer
18
Feb 8, 2016 12:46 PM
musickerns
1997 - 2003 F150
Jul 20, 2015 08:51 PM
Ford-Trucks Editors
2009 - 2014 F150
39
Oct 2, 2011 07:27 PM
sljim
2009 - 2014 F150
May 6, 2009 04:43 PM
