Front Shackle lift
Old Feb 25, 2010 | 07:52 PM
whitesdford's Avatar
whitesdford
Front Shackle lift
I saw someone on here had put a set of shackles on the back of the front springs for a little lift. Anyone know where I can buy some of these? My front springs are a little saggy anymore and need a little help.
Thanks.
Old Feb 25, 2010 | 07:57 PM
Ponyboychris's Avatar
Ponyboychris
I have a pair of these sitting on my workbench. I'm waiting for some decent weather to install them.
1999-2004 FORD-F250-350 2-1/2 SHACKLE LIFT KIT THE BEST : eBay Motors (item 230429979342 end time Feb-26-10 15:27:09 PST)
Old Feb 25, 2010 | 08:02 PM
big poppa's Avatar
big poppa
X2, I did it to mine and really brought the front end up..
Old Feb 25, 2010 | 08:18 PM
Gagew90's Avatar
Gagew90
not to try and steer ya away from doing that but replacing the springs is better, when you use lift shackles that lowers the pinion angle and puts more tension on the front u joints
Old Feb 25, 2010 | 09:02 PM
megawatt00's Avatar
megawatt00
This is very close to what I installed on my truck I did the one from Tuff Country though. Very nice set up and rides great.
Summit Racing SUM-G782 - Summit Racing® Front Suspension Leveling Kits - Overview - SummitRacing.com
Old Feb 25, 2010 | 10:36 PM
whitesdford
Jim,
Do you have any pictures of your dually before and after, or just after with these on there? My springs are sagging enough that when you turn the steering wheel, the tire hits the mud flaps at full turn.....
Old Feb 26, 2010 | 05:56 AM
megawatt00's Avatar
megawatt00
Originally Posted by whitesdford
Jim,
I will have to look around to get a couple from the same angle. When we installed them at one of our GTG's we forgot to take the required before and after shots. It did make a big difference though, even my 10 yo daughter felt the difference from sitting in the cab of the truck.
Old Feb 26, 2010 | 07:20 AM
robs01f250's Avatar
robs01f250
I also installed a new pair of springs and it made the truck come to life. Before I did it the truck looked like a 2wd truck and now it has the 4wd look back. Well worth the money, and not very hard to install either
Old Feb 26, 2010 | 12:15 PM
puller45's Avatar
puller45
Jim,
My problem was the same, mud flap rub, I installed the shackles noted on ebay and the problem was gone. IMO the lift you get is not going to have enough of an impact on the u-joints to cause a problem. I'm another happy shackler.
Old Feb 26, 2010 | 03:44 PM
wuttrd's Avatar
wuttrd
when i got my truck it was real low in the front. put a leveling kit in front still to low in front. built my own shackles worked and rides greatnow i am level.
Old Feb 26, 2010 | 06:03 PM
Gagew90's Avatar
Gagew90
i didnt mean to sound like it would be too hard on the pinion angle i just know shackling the front too much can do that i've only done the springs so you guys who have shackled it would obviously know
Scott51
Nov 14, 2016 09:15 AM
Rscottc
May 14, 2015 06:19 AM
380tom
Feb 22, 2013 07:36 PM
Newcomer
Offroad & 4x4
138
Dec 28, 2012 07:27 PM
jacked 86 f250
Feb 22, 2012 12:49 PM
