Need help
Old Feb 25, 2010 | 06:02 PM
Jbrown8988's Avatar
Jbrown8988
Need help
for a while my 02 f-350 has been acting weird. going 30 thru town at an even throttle the engine kinda dies a bit comes back and repeats all the time... RPM gauge drops about 200rpms when this happens.... it is just brief but continuous. I add fuel additive every fill up, replaced fuel filter, TPS in summer time was replaced. Also today while plowing...when i shifted from reverse to drive and hit the pedal it died. it started back up after a little extra cranking time....this happened 4 times today.
Old Feb 25, 2010 | 06:29 PM
Action4478's Avatar
Action4478
Have you swapped out the CPS yet?...
Old Feb 25, 2010 | 06:35 PM
Jbrown8988's Avatar
Jbrown8988
no... i actually got another recall letter the other day about it. I thought everyone said the new ones suck.??
Old Feb 25, 2010 | 10:17 PM
GEugeneS's Avatar
GEugeneS
I think the consensus is the new ones do suck, but they do fail and that's why the recall. But most of us decided to stay with the old one until it failed. Yours may be failing. I would say let 'em replace it, see if that helps, and then see if you can find a gray one, or is it the black one? Brain dead tonight. Someone else will correct me. When you get the "good" one, replace the factory recall cps.
Old Feb 25, 2010 | 11:00 PM
PaysonPSD's Avatar
PaysonPSD
Besides the CPS another thing to check would be the 42 pin connector and the wiring harness leaving each side of it. This connector is below the air intake hose above the driver side valve cover. Check the harness for chaffing and make sure the connector is tight. The harness has been known to rub on the valve cover and also on the inboard side of the bracket holding it. The diagram shows the connector with the intake tube removed from air flter housing.
Old Feb 26, 2010 | 01:14 AM
duck fan's Avatar
duck fan
Because racetruck
I was dealing with a very similar issue. I was working on some other issues with my truck and checked the 42 pin connector. The 10mm bolt that holds it together was about 2-3 turns loose. Check it out
Old Feb 26, 2010 | 09:10 PM
Jbrown8988's Avatar
Jbrown8988
ok guys it got real bad today! i took it in and had them pull the codes and i got: P0122, P0221, P1211
Old Feb 26, 2010 | 09:28 PM
Vinford's Avatar
Vinford
Mines doing the same thing.
It almost feels like its just coasting sometimes then it kicks in and away it goes.
I notice it going downhill and its only for a second or so, not enought to really pinpoint what its doing?
Old Feb 26, 2010 | 09:30 PM
PaysonPSD's Avatar
PaysonPSD
P0122 -- AP -- Accelerator pedal sensor circuit -- low input, Grounded circuit, biased sensor, PCM.
P0221 -- AP/IVS -- Throttle switch B circuit performance -- Failed pedal assembly
P1211 -- IPR -- ICP pressure above/below desired -- IPR valve failed, stuck, or shorted to ground
2 out of 3 point toward the accelerator pedal. I would start there.
0122 is a fault with the TPS (Throttle Position Sensor)
0221 Is a fault with the IVS (Idle Validatiob Switch)
You either need a new IVS switch or a new TPS. Both are on the loud pedal. I don't know if they are separate on a 2002. I know on my E99 they are separate parts.
Both these codes can be caused by dirty conacts. If you can get at the contacts a good spraying with electrical contact cleaner may suffice.
I'm sure some who has experienced this will chime in.
The 1211 is most likely caused by your tuner asking for more ICP then your HPOP can deliver. Its common and won't hurt anything,
BUT something to look at if it is not the IVS or TPS.
EDIT: Someone pulled the codes and woldn't even tell you what they were. Would that be an extra charge?
Old Feb 26, 2010 | 09:39 PM
Jbrown8988's Avatar
Jbrown8988
I replaced the TPS this last summer. BUT... i bought it on ebay! haha so i just ordered one from Ed. Hopefully he ships fast! Thanks You!!
Old Feb 26, 2010 | 10:05 PM
PaysonPSD's Avatar
PaysonPSD
Did you have the same symptoms last summer?
Was the ebay part OEM?
Old Feb 26, 2010 | 10:11 PM
CPUNeck's Avatar
CPUNeck
Does the pitch of the engine change? Sounds to me like it may also be a fuel pump going bad... have you tried a good 3/4+ throttle launch to see how the truck reacts. If your fuel pump can't keep up the engine sound should "ping" a lot more as it's starving for fuel.
Old Mar 1, 2010 | 12:51 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
AS FAST AS YOUR CHECK BOOK ALLOWS.
Old Mar 1, 2010 | 01:02 PM
Jbrown8988's Avatar
Jbrown8988
Hey Ed thanks for noticeing i ordered the wrong part!! Kudos to a smart man!
Old Mar 1, 2010 | 01:49 PM
Parts Guy Wyatt
Former Vendor
YOU ARE WELCOME.
Thanks for the order.
Paul T
Aug 25, 2014 08:33 PM
78 & 87 Super Cab
19
Sep 8, 2013 10:37 PM
jetmon135
Aug 6, 2013 01:37 AM
och
Sep 2, 2012 09:30 AM
RichPSD
15
Dec 23, 2005 07:32 PM
