Offroad & 4x4
Lift?
Old Feb 25, 2010 | 06:03 PM
bogger1966's Avatar
bogger1966
Originally Posted by kjett
Don't waste your time Don. People like this think "beating the hell" out a truck with 1/2 ton axles and 44's are talking about climbing the speed bumps at the local mall.
But on a serious note, 4.56's would be overkill for 44's. Somewhere around 2.80- to as low as 3.55 would be perfect and get somewhere in the neighborhood of 17-19 mpg.
i know what beating the hell is, where i live there is huge trucks that run around all the time.
why so high of a gear ratio? im not looking for good mpg's
Old Feb 25, 2010 | 06:05 PM
bogger1966's Avatar
bogger1966
Originally Posted by Truckin4life
Truffcupcakes
Hey, i take my truck to the mall, quite often, happens to be that the mall also shares a parking lot with home depot...
My truck would probably break if i tried to crawl over a speed bump, man thats a little to extreme for me...
what is a truffcupcakes?
what is all this talk about malls and newbs? im just trying to get info for a lift kit for my truck.....can anyone suggest one?
Old Feb 25, 2010 | 06:08 PM
bogger1966's Avatar
bogger1966
I did see a ranger running around here with 44's and the stock axles. He had a 302 swap in it and flogged it off road quite a bit, so the D44 ttb should be fine for your needs. As for the rear, if you can't get new springs, try looking for some interlocking bricks. They work in a pinch
Now for the body lift, they can be quite expensive, so head down to your local sporting good store and get a bag of hockey pucks. Stack 3 together by using some gorilla glue, then drill the center for a longer body bolt. If you are anywhere near Florida, theirs some douchebag down there with a big underpowered lawn orniment that has a body lift he might be pulling off his, so you can see if he'll sell it to you cheap.
are you being sarcastic? i would like to do it right, so im going to use a real block lift and body....i am located in FL where would i find this body lift?
Old Feb 25, 2010 | 06:11 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
Hey F awker.....dont talk chit
Old Feb 25, 2010 | 06:13 PM
quadzjr's Avatar
quadzjr
bogger....
you just need to quit while your ahead.....and do some gad dang searching.....there is PLENTY of info on this here.
i really just dont know where to start.
Old Feb 25, 2010 | 06:30 PM
alpha/omega's Avatar
alpha/omega
where?
<fiiiiiiiiill>
Old Feb 25, 2010 | 06:32 PM
quadzjr's Avatar
quadzjr
well, he may have to look back a few years......he can start by looking at mine...lol
Old Feb 25, 2010 | 06:44 PM
alpha/omega
bwahahahahahaa! biggest joke EVAR!
Old Feb 25, 2010 | 06:46 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
I say run a 14.69 ratio might be tricky to find, but there out there, its a pefect gear match for your rig...
I dont think 600 horses will be enough, a nitrous setup is likely in your future.
Have you thought about cutting the boggers?
Its for weight saving so you can spin them faster, leave the big lugs cut the small ones out.
Lockers is also a good idea for your build, lincoln makes top notch ones.
Interlocking bricks is the best lift todate... Way ahead of todays technologies....
Old Feb 25, 2010 | 06:54 PM
alpha/omega
14.71 is a Dana ratio.
nothing less than a double 500 fog
for lower hp rigs Id cut the big lugs out and only leave the small and medium ones.
how do those compare to Miller lockers?
legos FTMFW!
Old Feb 25, 2010 | 07:34 PM
quadzjr's Avatar
quadzjr
LOL....i thought you'd get a kick out of that
bish, dont hate!
Old Feb 25, 2010 | 07:45 PM
bogger1966's Avatar
bogger1966
why are you guys *****ing around with me?
i just would like someone to point me in the right direction....
theres no such thing as that ratio
i think 600 will be more then plenty
i want it to be street legal
ive been thinking about lockers but i want to get the lift done first
Old Feb 25, 2010 | 07:51 PM
  #28
dillinewton's Avatar
dillinewton
bahahahaha
  #29
captain p4's Avatar
captain p4
PM "Prozon", he's resident expert on lifts.
Old Feb 25, 2010 | 08:01 PM
  #30
kjett's Avatar
kjett
Yep, and Quadzjr is the resident expert on body lifts. Ask him about where he got his.
