Sponsored by: Auxito
what does this mean?
Old Feb 28, 2010 | 08:11 PM
93 mix 'n match's Avatar
93 mix 'n match
Originally Posted by windstar99
First thing first. Don't automatically think the Cat is gone. When this type of code appears, it's beyond a "backyard" mechanic diagnosis. You don't want to throw good money at bad and replace the cats and it turned out to be a sensor or wiring issue.
The code is telling you that the sensor Bank 1 Stream 2, downstream of the cat (after), is reading out of Spec. There is a posibiltiy that the upstream sensor is bad, causing a rich mixture on one bank or the other. Thus causing the downstream sensor to read out of bounds also.
What needs to be done at your local garage or Dealer, is they can drive the vehicle and monitor what each O2 sensor is doing in real time. Also they can see is it's also a wiring issue. They will let you know for sure if it's the sensors or the cat. My hunch is the sensor. If it was the cat, there would be a greater issue of driveability.
Lastly, O2 Sensors are a lot like spark plugs. They don't last forever. They only have a service life of about 60,000 miles (100,000 kms) Thus, they will wear out even if there is nothing wrong with your cats.
I have a 2002 Supercrew with 145,000 Kms. I have already replaced 2 of them.
i replaced one the day after i got the truck, i have the other 3. im just waiting for a day above 40.
the software i have for my computer lets me see all the sensors in real time while the truck is running. im no pro, but all the o2 sensor data looks like there all functioning correctly. ill try to catch some video of the program.
Old Feb 28, 2010 | 08:39 PM
93 mix 'n match
got it.
video-2010-02-28-21-18-50.flv video by Louie2994 - Photobucket
davbeisner
Sep 15, 2012 05:39 PM
boulderguy
May 16, 2012 12:04 PM
Canadian_Cowboy
Aug 3, 2010 06:03 PM
Blue'87GT
1978 - 1996 Big Bronco
24
Nov 20, 2004 10:30 PM
roofrack
Jun 3, 2004 10:02 AM
