Rear hatch sensor
Old Feb 25, 2010 | 08:25 AM
amkkba's Avatar
amkkba
Rear hatch sensor
My door ajar light and interior lights stay on after I open and close the rear hatch. I have read to change the sensors. How hard is this to do? It is the driver side sensor.
Old Feb 25, 2010 | 10:19 AM
RMBC Freeride's Avatar
RMBC Freeride
Not too bad. Easier than removing the front door latch/switches IMO.
You just remove the plastic surrounding the rear window glass to get access to the switch. then remove the 2 (or 3?) screws from the outside that hold it to the hatch, disconnect the wiring harness plug and the cable.
All that being said, have you tried some WD40 on it just for grins before replacing. Sometimes does the trick...
Old Feb 25, 2010 | 11:34 AM
amkkba's Avatar
amkkba
I will try to WD-40 first. Thanks!
Skip1970
Sep 7, 2021 05:59 PM
ExPACamper
Oct 15, 2017 04:06 PM
DaveinTulsa
Nov 17, 2014 01:11 PM
Glenn Blackwell
Aug 6, 2014 05:15 AM
hamiltonfighter
Jul 14, 2012 09:52 PM
