One other note, when I took the alternator off, I took it to the normal auto supply houses and had it tested. Three different ones to be exact and each time the alternator tested "good". I checked all the wiring and the ground and everything was good. I decided to go with just new batteries due to the alt. checking out good. Put the new batteries and old alternator back on the truck and drove it to a funeral about 3 hours away. All was good on the way over but on the way back the battery light came back on. Got home and checked DC power on the batteries with the truck running and the voltage was only 12.1 volts. I think it is suppose to be ~14V so I decided to go ahead and replace the alternator and that has fixed the problem. I doubt seriously that the alternator failed on that trip.
Just adding some experience.
Bad contact at the field winding connection would have exactly the same symptom.
And your act of R&R of alternator could have just tweaked the connector enough to give a good contact.
Note: the other possibility is the wiring went bad internally inside the housing!
I guess I am high man so far, mine lasted 118,000 and when it went no warning light was thrown. Fortunately for me the batteries I was running on got me home with no instrument gauges.
See my wiring fault page for details.
Agreed. I had read your posting when I was troubleshooting this. Great info BTW. I figured I was past that when I had the alt. off and then reinstalled it but who knows. I didn't care much for uninstalling and reinstalling the alt. twice in the freezing rain but it works now :-).
My alternator quit at about that mileage but the ford garage replaced it for around $500and this one has about 30,000 miles on it and it is working, thought it was just a fluke.
