Battery or Alternator?
Old May 31, 2007 | 01:25 PM
92F150Flare's Avatar
92F150Flare
Unhappy Battery or Alternator?
My "charging System Failure" light just lit. I should be able test the alternator by reading the battery while the truck is running?
Anything else it can be? Any other tests?
Thanks.....Bob
Old May 31, 2007 | 02:21 PM
Conanski's Avatar
Conanski
You should get 13.5+ volts across the battery with a multimeter while the engine's running, and 12+ volts with the engine off. If you only get 12v or less with the engine running the alternator or it's internal regulator has failed.
P.S. If the alternator fails this test, and you take the alternator to a parts house and they test it on one of those quick benchtop testers and say it's good, ignore them and get another alternator anyway.
Old May 31, 2007 | 04:14 PM
netscaner's Avatar
netscaner
A fully charged battery sits at about 12.75 volts with the engine not running and everything turned off. It might be slightly lower on older or not perfect batteries.
With the engine running it should be 13.50 -16.00 depending on how much it's charging.
If it stays above 13.25 with the engine running and the headlights on, your alternator should be OK.
You might want to check your body ground by scratching a clean shinny spot on your fender inside the hood area, and measure from the center of the negative battery cable and that spot with the engine running and the lights on. It should read 0.00.
Old May 31, 2007 | 05:23 PM
hillbilly delux's Avatar
hillbilly delux
Go to harborfreight.com and order yourself a battery load tester they also have a function for testing the charging system. as cheap as they are they make life a whle lot easier. Mine earned its place in my toolbox the first time i used it.
bob6860
2004 - 2008 F150
Apr 27, 2013 09:19 PM
Texas Bob
Nov 25, 2011 05:19 PM
c125bob
15
Sep 17, 2008 03:44 PM
califasbob
Electrical Systems/Wiring
Dec 9, 2006 02:31 PM
find20
Apr 9, 2004 10:15 PM
