Sponsored by: Real Truck
replacing brake caliper....
Old Feb 24, 2010 | 04:42 PM
ilo9's Avatar
ilo9
Question replacing brake caliper....
Anyone give me steps to replace brake caliper on right rear of 04 f250....Had left rear done one year ago and now right is stuck with newish pads on it. is all I have to worry about crimping brake fluid line and then use brake pad change thread?????
how do I get seized caliper off???
I have a heated shop so I am not worried about fixing it just want to make sure I do it right...
How much for new caliper???
any help appreciated <!-- / message --> <!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --> <!-- END TEMPLATE: ad_showthread_firstpost_sig --> <!-- sig --> __________________
2004 6.0 KR F250
STOCK!!!!!!!!!!
Old Feb 24, 2010 | 04:47 PM
Maxium4x4's Avatar
Maxium4x4
I moved you to SuperDuty, the guys will be right along to get you going.
Old Feb 24, 2010 | 05:01 PM
ilo9's Avatar
ilo9
thanks your the man
Old Feb 24, 2010 | 05:37 PM
mnpowerstroke99duty's Avatar
mnpowerstroke99duty
All you have to do is unbolt it and pry it off,disconnect brake line.I just put a pan under it to catch fluid.I'd buy a semi loaded caliper it comes with the bracket it bolts to.I get mine at NAPA.The reason they usually stick is the sliding pins get stuck and won't release the caliper.Make sure you get some synthentic caliper grease for the slide pins.I try too check the slide pins once a year when rotating the tires.To install: I bolt the bracket on then put the brake pads on the bracket then slide the caliper over it ,put on brake line,then put a clear hose over the bleeder and other end in a container with some brake fluid in it. Then have someone pump the brakes and hold the pedal down and loosen the bleeder screw until some fluid/air comes out and pedal goes to floor.Then tighten it and repeat until all that comes out is fluid[make sure to keep the master cylinder full].Put tire on and your done.
Old Feb 24, 2010 | 05:56 PM
06silvercrew's Avatar
06silvercrew
Hydraulic components should ALWAYS be replaced in pairs..
RA21925
23
Dec 7, 2013 11:44 PM
wrangler2520
Dec 6, 2010 11:36 AM
sddesigns
New Jersey Chapter
Apr 20, 2010 06:58 PM
sddesigns
New Jersey Chapter
Apr 14, 2010 01:57 PM
jcrite63
2004 - 2008 F150
Mar 17, 2010 04:52 PM
