4x4 no work
Old Feb 24, 2010 | 12:22 PM
jasvid's Avatar
jasvid
4x4 no work
Hi Guys,
Back to the well for more advice. I have my work truck in the field and my guys report that 4x4 isn't working - it isn't working in Low or High.
This truck is a 97 F-350 with factory auto hubs - 215K on the odometer and Auto Transmission.
I am trying to diagnose from afar. 4x4 light work correctly for high and low. Shift lever feels normal in moving from 2wd to 4H to 4L.
I read another post where someone recommended trying the heater and blowing air to the floor - apparently if the air goes to the defroster instead, it means you have a vacuum leak and then the hubs wouldn't engage - can anyone confirm the validity of this test? The air blew on the floor when I had my guys try this.
Any and all help in diagnosing from afar (can't afford much downtime when it comes home) is appreciated. Thanks!
Old Feb 24, 2010 | 02:45 PM
JethroF250's Avatar
JethroF250
your hubs could be shot. my truck had autos and the driver side got stuck half way so it popped real hard in 4 wheel but did nothin in 2. it turned out it blew so it got stuck. i did a manual hub conversion from Warn for $317
Old Feb 24, 2010 | 03:52 PM
tjbeggs's Avatar
tjbeggs
one or both of your auto hubs is not locking in. Probably time for new autos or a better solution is to do the manual hub conversion
