Need help with fuel gauge
Old Feb 24, 2010 | 09:39 AM
strokinout's Avatar
strokinout
Hey everyone. I have done some searching on this issue, but everybody's issue seems to be different than mine. I have a 1996 F-250 and my fuel gauge for my front tank doesn't work. It reads empty all the time with no jumping or floating of any kind. However, my rear tank's fuel gauge works. But when I switch to my rear tank, the truck dies like it's not getting anymore fuel a few seconds after switching. I don't really know where to start so could anyone point me in the right direction? I'm kind of lost on this.
Old Feb 24, 2010 | 09:57 AM
andym's Avatar
andym
Sounds exactly like what my 1990 F-150 with dual tanks was doing.
The pump on the rear tank was weak and wasn't putting out enough pressure. So the engine wouldn't run on that tank.
The sending unit on the front tank had a hole in the float... so it wouldn't. Tank always read empty.
I ended up pulling the bed off and replacing both fuel delivery modules.
Old Feb 24, 2010 | 10:31 AM
strokinout's Avatar
strokinout
Is there any way to get around pulling the bed off? I'm by myself and if it's heavier than the toyota pick up bed I pulled, I'll have to put it off. Thank you much for the info by the way.
Old Feb 24, 2010 | 10:34 AM
andym's Avatar
andym
No problem.
You can drop the tanks.... but usually if you're pulling both pumps the bed route is easier.
Another thing to consider is that if you just replace the bad pump, you can fill both tanks up and then drive the front tank until it runs empty. Then just switch to the tank where the gauge works. That's what I did and it worked out great.
Old Mar 1, 2010 | 10:52 AM
strokinout's Avatar
strokinout
I was curious as to where I could get a fuel float from? I've looked at Advanced and Napa's online site, but I can't find any? Do you have to buy a whole new sending unit?
Old Mar 5, 2010 | 10:41 AM
strokinout's Avatar
strokinout
Alright, everyone. I am now the proud owner of a new fuel tank and a new fuel pump. I found out the fuel tank was bad as soon as I poured the gas out and it came out rusty colored. I looked in the tank and just shook my head. Now that I have it all back together, the fuel gauge for the rear tank reads WAAAY past full. The whole point to dealing with the rear tank was to have a tank with a working fuel gauge. I'm stumped. Any suggestions out there?
Bradley
Old Mar 5, 2010 | 12:20 PM
BCHauler's Avatar
BCHauler
Check your ground connections. I think a pegged gauge usually indicates bad ground connection. If you can recheck the connection between the harness and your new pump. Then follow the ground wire back.
My 0.02
Old Mar 5, 2010 | 12:44 PM
strokinout's Avatar
strokinout
Thank you much, sir. I don't know if this helps, but it did work before. BTW I wanted to do the bronco tank swap, but I already had the fuel pump here and paid for. Thanks for the writeup. Would you happen to know where the ground would be for this? I'm going to start from the connection on the pump. Again, thank you.
Bradley
tkisling
Dec 25, 2013 09:47 AM
Truck Guy99
Nov 28, 2013 10:39 PM
Ryan.J.M.
Nov 1, 2012 06:31 AM
0351mike
1966 - 1977 Early Broncos
Aug 20, 2009 04:22 PM
87f150xlt
15
Nov 9, 2004 12:19 AM
