carb questions...
Old Feb 24, 2010 | 12:15 AM
'83f3fiddy's Avatar
'83f3fiddy
carb questions...
1. where can i get a cheap oem or oem equal carb.
2. with a carb from a junk yard 461 fit on top of my 351W.
3. will a carb that's too big cause a bad vibration at idle and under load?
Old Feb 24, 2010 | 10:16 AM
Franklin2's Avatar
Franklin2
A cheap carb that will work without a rebuild? They don't exist. The new fuels they use with all the alcohols ruins them in short order if they sit around for a few months.
If it has the same bolt pattern, it will fit. But the same rule for the first question still applies. A junkyard carb is probably going to need a rebuild.
Usually not. More than likely you will dig up old carb after old carb, all have been sitting around, and all I have old gummy fuel inside them. Getting any of them to work correctly will be a gamble.
Old Feb 24, 2010 | 08:38 PM
kermmydog's Avatar
kermmydog
I agree with Dave. Every time I ever tried to do CHEAP it as a rule cost more money than if I would of bought rebuilt or new.
What is the OEM carb your trying to replace?
Craig
Old Feb 24, 2010 | 09:08 PM
'83f3fiddy's Avatar
'83f3fiddy
i have a holly 4 barrel that is not for my truck on it right now (came with truck) and i wanna be able to 1 see if an OEM carb will fix the issue, and 2 what it will cost..
Old Feb 24, 2010 | 10:14 PM
Franklin2's Avatar
Franklin2
I am assuming you have a 460? If so, the original carb is a 4bbl made by holley, but it has lots of vacuum ports that you will probably have to plug to make it even work. I am also assuming you have a aftermarket carb that does not have very many lines on it correct?
Old Feb 24, 2010 | 10:27 PM
'83f3fiddy's Avatar
'83f3fiddy
actually its a 351. and i got 1 or 2 vac lines and they are both plugged...also when i floor it i get this weird *** noise that i cant explain at all..sounds like a loose rod banging around but only when at 3/4-WOT at cruise i dont hear it and when towing a car i dont hear it unless im in that throttle band
Old Feb 25, 2010 | 01:53 AM
Piffery1's Avatar
Piffery1
I have doubts that a carburetor could cause a knocking sound. Pre-ignition or detonation sounds, yes- due to too lean a mixture or timing too far advanced. I'd first try retarding the timing. Your truck with 351 and a four-barrel carb used a Holley (Motorcraft) 4180C. If that's what you have then get a good kit and a new correct power valve and rebuild it. I suggest a Holley or Walker kit and power valve. Use plenty of spray carb cleaner and lots of compressed air to clean all the passages. The above named kits have very good instructions.
Old Feb 25, 2010 | 06:08 AM
'83f3fiddy's Avatar
'83f3fiddy
the only numbers i could find on the holly is a 1980 number...
Old Feb 25, 2010 | 09:07 AM
82F100SWB's Avatar
82F100SWB
Have a look at the choke horn, you should find the List number along with a Ford engineering number if it's a factory carb, like so
Onve you have the list number, take a look here:
http://www.holley.com/data/TechServi...%20Listing.pdf
If it's not there, call them, they should be able to tell you the application, and all of the stock specs for the carb.
This page will be able to help you with the Ford engineering number and give you the application if nothing else:
Ford V8 Truck Carburetor Parts - The Carburetor Doctor
If it is a factory 80's Ford/Holley carb, it's a 600 CFM 4180C, no matter if it came off of a Mustang 5.0, a 351W or a 460.
Old Feb 25, 2010 | 09:27 AM
'83f3fiddy's Avatar
'83f3fiddy
i just got 2 lines on my carb..but its not the carb for my truck cause 1 the throttle cable dont hook up right and 2 the kick down road dont hook up at all
Old Feb 26, 2010 | 02:25 AM
Piffery1's Avatar
Piffery1
Get a Holley 4180C for an automatic trans vehicle from a junkyard and rebuild it. You can often find kits on ebay for much less than at auto parts stores. Junkyard price should be about the core value.
Old Feb 26, 2010 | 04:45 AM
'83f3fiddy's Avatar
'83f3fiddy
well i have a "high performance" holly tric kit or what ever it is...
Old Feb 26, 2010 | 11:53 AM
Piffery1's Avatar
Piffery1
Why don't you contact Holley's online Technical Service, give them the info on your carburetor and truck, and ask them for advice about what to do to make it right for your vehicle? You'll probably at least need adapters for the kickdown rod and the throttle cable. You may also need a proper power valve to match your engine.
Old Feb 26, 2010 | 02:02 PM
'83f3fiddy's Avatar
'83f3fiddy
yeah..im thinking of just going back to stock tho get rid of the holly if the rebuild dont fix the issue, then ill find a stock 2 or 4 barrel
ESKY021
3.0L V6
Apr 28, 2026 05:16 PM
Penn79
May 31, 2014 12:16 PM
R L Sullivan
13
Apr 30, 2012 06:35 PM
'83f3fiddy
WTB - Parts & other
Feb 24, 2010 06:44 PM
Chumbucket
Mar 18, 2008 02:56 PM
