05-F150 question
Old Feb 23, 2010 | 09:03 PM
water 5's Avatar
water 5
Question 05-F150 question
Having some things happening...
The first one is when the temp is below 30, the truck whistles. It doesn’t do it all of the time - just mid-speed.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
The second is that the truck is starting to have a knock noise in the engine. Is this something ford is fixing? The truck is still under warranty so I would like to get it fixed before it runs out.
Thank for your input.<o></o>
<o></o>
Old Feb 23, 2010 | 09:12 PM
Smokey01's Avatar
Smokey01
thats weird i just noticed my 08 doing the same thing.....are you hearing the whistle in the cab while driving?
Old Feb 23, 2010 | 09:14 PM
water 5's Avatar
water 5
yes you can hear it in the cab.
Old Feb 24, 2010 | 11:00 AM
FTE Trigger's Avatar
FTE Trigger
For the whistling...
Check your alternator or tensioner pulley...
There has been "issues" on that in the past...
Old Feb 24, 2010 | 11:51 AM
jdrahush's Avatar
jdrahush
My bet would be the whine is from the alternator. I had the same problem with my 2002. I checked the amperage output myself, and also had a shop check it and the alt was working really well, it just had a whine. Moral of the story: your alternator is probably working fine, its just making an annoying noise. My whine went away in warmer weather so I just left it.
Old Feb 25, 2010 | 06:44 PM
danorules's Avatar
danorules
in cold weather I had the same whistle only while driving. turned out to be a leak in the third brake light. the gasket had a problem with it and would shrink in the cold weather. the gap would whistle while moving. easy fix , if that is the problem
Old Feb 28, 2010 | 11:29 AM
Savage072's Avatar
Savage072
Is your knocking loud enough to here in the cab. I have a 05' 5.4 and when it gets warmed up it sounds like a Diesel F250/350. I went to the dealer to have them look at it and they said it was normal for f-150's 04-09. What a crock.
TexasEX2K
Jul 5, 2012 10:46 PM
ABF PSD
Feb 9, 2012 09:26 PM
56yroldkid
Escape & Escape Hybrid
Apr 12, 2011 09:28 AM
NAMDROF
13
Apr 5, 2011 11:02 PM
MaxOut
Oct 19, 2009 08:12 AM
