Truck dead again
Old Feb 23, 2010 | 08:57 PM
jmurana's Avatar
jmurana
Cool Truck dead again
I need help before I shoot my ford f350 truck. I replaced both in tank fuel pumps tested the fuel selector switch replaced oil pressure switch and fuel cut off switch and tested the inertia switch. I jumper-ed the the fuel pump selector switch it has power and moves. i checked for power into the new fuel pumps but the pumps don't come on. I need help please what am i missing? 1986 ford f350 dually crew cab with dual tanks with electric fuel pumps.
Old Feb 23, 2010 | 10:28 PM
Franklin2's Avatar
Franklin2
Is your fuel pump relay working? It's powered by a oil pressure switch on the engine. I am assuming you have a 460?
Old Feb 23, 2010 | 10:31 PM
jmurana's Avatar
jmurana
yes fuel pump is working and the oil pressure switch is new and it is a 460
Old Feb 24, 2010 | 10:43 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
what about the fuel shut off valve, I've sold about a million of these
LOOK AT THE 9N176
Old Feb 24, 2010 | 06:42 PM
Franklin2's Avatar
Franklin2
Did you say in your first post you do have power to the pumps at the tank? If so, it may be a grounding problem with the pumps.
Old Feb 24, 2010 | 10:10 PM
jmurana's Avatar
jmurana
I have to pull both tanks because there is power to each pump but they don't work.
Old Feb 25, 2010 | 07:23 AM
bashby's Avatar
bashby
are you disconnecting the wiring at the tank to check for power? try probing the wire with it connected to the pump. Then check for ground. If you have both and the pump wont run the pump is bad or the wiring in the tank
Old Feb 28, 2010 | 04:56 PM
jmurana's Avatar
jmurana
Yes i have power at both tanks so i have to pull them both. Any other ideas? I really would appreciate them. I thank every one for there help in my problem
Old Feb 28, 2010 | 04:59 PM
jmurana's Avatar
jmurana
Can you get me a price on ford fuel pumps for my truck ? 1986 f350 460 carbed and two wheel drive dually with dual tanks both are steel tanks.
biztyke
Jun 12, 2013 01:27 AM
jason kitch
Apr 13, 2012 03:04 PM
Hobo81
Aug 18, 2011 08:08 PM
str8racing
Jul 17, 2007 09:56 PM
darrengj
Electrical Systems/Wiring
Nov 15, 2005 09:48 PM
