I'm looking for a wiring diagram book if they are available. I bought a factory Ford wiring diagram booklet for my 2002 several years ago but can't find who I bought it from. Now I'm needing one for my 1995.
Does anybody know where I can buy one? I've searched google, but haven't had much luck.
I'm specifically needing the engine harness connection to the motor compartment harness. You know, the big square one on the driver's side inner fenderwell!!! I'm also looking for the wire connection at the vacuum pump distribution block (next to the large squre engine harness plug).
If ANYONE can help with a pdf of these connectors and diagrams, or where to buy a book, then please let me know ASAP!!!!
You need PCM Or IDM... IDM is bolted to the fender , PCM is behind the parking brake ...I think I saw a post that included a PCM pinout with labels a week or so , I''ll see if I can find it...
Neither.
I'm looking for the connection that the engine plugs into. It's the square one tucked under the master cylinder on the driver's side inner fender well. It's also right next to the vacuum distribution block. The PCM and IDM wires go into it, but it's were the psd motor harness connects.
Look in my webshots. Diagram are there and in the tech folder are some connector views. See if those help you. Click the picture in my sig to go there.
Thanks Bill. I'll check those out. My roommate was telling me about AllData. He might even have access to it.
I'd love to check them out Tim, but Webshots crashed my computer last week. It makes my malware, spamware, and antivirus go NUTS for some reason. Last week I tried to look at some webshots photos of one fo the members here and when the page loaded, my machine got infected with some sort of malware. Our work IT people worked on it for a while with no luck.
So unfortunately, I gotta stay away from there which sucks because I can't even get into my own webshots account!
