I need help!
Old Feb 23, 2010 | 01:15 PM
dirtroad85's Avatar
dirtroad85
I need help!
I have a 69 F100, 360, 3 on the tree. I haven't had it long though, but I've fixed the exhaust, or lack of, re-tuned the carb, and had it running ok for about a week or so. Now it just shuts off, just like you turned the key off, its intermittent, sometimes it does it while idling, sometimes going down the road, push the clutch, turn the key and it comes back, most of the time. New cap, points, rotor, not plugs yet, but I'm stuck. Any ideas would be much appreciated.
Old Feb 23, 2010 | 01:48 PM
starmilt's Avatar
starmilt
I had this happen once and it took awhile to find, mine turned out to be a bare spot on the coil wire and every once in a while it would short against the air cleaner. Just something to check.
Old Feb 23, 2010 | 02:22 PM
montana_highboy's Avatar
montana_highboy
Loose wire connection on coil? ignition switch going bad? those are few things i'd check.
79F250isalive!
Oct 19, 2014 05:58 PM
bradahl
1997 - 2003 F150
Aug 21, 2014 05:20 AM
jbworm20
Feb 24, 2012 09:25 AM
bigal6030
Jan 11, 2010 10:07 PM
wintremute
65
Mar 21, 2006 10:56 AM
