Differential lube
Old Jan 20, 2003 | 05:23 PM
scionti 94's Avatar
scionti 94
Differential lube
What weight differential gear lube should I use in my '94 Bronco,8.8, 3:55 limited slip. I've got Valvoline 80-90 wgt with the Ford additive in there right now. When year did Ford start using the synthetic 75-140 wgt. in the differential? There seems to be some differing opinions on what weight to use.
Thanks.
Old Jan 20, 2003 | 06:23 PM
1984_355w's Avatar
1984_355w
Differential lube
What you have in there now is fine.
Old Jan 20, 2003 | 11:16 PM
83Steve's Avatar
83Steve
Differential lube
Dana and Ford rear axles use Premium Rear Axle Lubricant XY-80W90-QL or -KL or equivalent meeting Ford specification WSP-M2C197-A.
It is recommended that the lube be replaced in all rear axles at 100,000 mile intervals, or if the rear axle has been submerged in water, or more often under certain extreme conditions. High Performance Synthetic 7W-140 Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A is available for repairs and refills in situations that fall into the severe or extreme use categories.
Of course, that "7W..." is a typo, but it's exactly what's on this CD. In another part, it shows:
Service Fill for Severe Use, Dana, F-Super Duty Rear Axles-----75W-140 Synthetic Rear Axle Lube ------ P/N: F1TZ-19580-B ----- Ford Spec: WSL-M2C192-A
Old Jan 21, 2003 | 06:43 PM
scionti 94's Avatar
scionti 94
Differential lube
Appreciate the opinion and information. It is most helpful. I have 108,000 miles on the odometer. Bronco is basically used on the interstate between Fla. and Ga. Great road vehicle. Plan to keep for a long time, thus the reason for wanting to make certain that it is getting the right care.
Old Jun 5, 2023 | 02:28 AM
steverinaz's Avatar
steverinaz
Does this fluid work for my 13 F150, FX4, Electronic locking diff
Hello all,
Time to replace the rear differential fluid looking at Triax Synergy Gear Max, 75W-140, synthetic. It's supposed to contain a friction modifier in it but will it harm an ELD ?
Old Jun 5, 2023 | 06:32 AM
projectSHO89's Avatar
projectSHO89
Factory service manual explicitly says not to use friction modifier in an ELD. Doesn't give a reason.
Call the manufacturer of the lube and see what they say.
Old Jun 5, 2023 | 12:59 PM
steverinaz's Avatar
steverinaz
Differential lube
Waiting for a response, however I see that many 75w-140 synthetics have a modifier included.. "scratches head"..
Thank you!
Old Jun 6, 2023 | 08:22 AM
1Butcher's Avatar
1Butcher
What is so special with that oil that you would want to be the first to use this? Curious. There are so many other oils that people have used and have had good results.
Old Jun 6, 2023 | 08:59 AM
steverinaz's Avatar
steverinaz
Kick butt pricing. And I have a credit on the big Amazon account...
Old Jun 7, 2023 | 07:52 PM
Blurry94's Avatar
Blurry94
If it had 80w90 with friction modifier, then that's what I'd put back in it. As for synthetics, I don't believe you are gaining anything with that, and some aftermarket LSD manufacturers don't recommend it with their clutch type lockers. There may be a difference going from 80w90 to 75w140 for vehicles in warmer areas, but IMO, that would even be for extreme duty.
I use conventional, middle of the road 80w90, with 1 bottle of Ford friction modifier in my Lightning 8.8 with an Eaton LSD. I have beat the crap out of it over many years and no issues due to the gear oil...just my .02.
Old Jun 7, 2023 | 09:18 PM
1Butcher's Avatar
1Butcher
I like synthetic oils and I am too old to be a guinea pig to experiment on cheap products. I also like thick oils. I get that thinner are where it's at and better for MPG, but when I barely get 5mpg when I tow my 5th wheel, I'm not going to seem much improvement.
rvpuller
May 9, 2022 10:52 AM
fixit5561
2015 - 2020 F150
Feb 3, 2022 08:51 AM
Zoidberg
Oil & Lubrication
Apr 25, 2021 08:42 AM
DrFord
Oil & Lubrication
18
Mar 22, 2010 11:47 AM
trike1946
Nov 3, 2006 05:21 AM
