Help, I'm new too engine mods and need advise
I've only heard of the 360's having it, and if you look at a part catalog, like Napaonline.com, you'll see 390 timing sets are for all years with one part number (at least, the late 60's into the 70's), and the 360 sets are divided into two part numbers. Pre 1972, and 1972 and up.
So, looks like ONLY the 360 had the retarded set (no pun intended)
'73 360/390 both list the same timing set #203012 $31.99 (straight up)
'74 360/390 both list the same timing set #203021 $37.99 (retarded)
I just looked up 360/390 timing sets on Napa online and they list 390's with two different part numbers as well, with '73/'74 being the divide, the very same as the 360's...
Just checked RockAuto.com (one of our sponsors) and Sealed Power shows pretty much the same division. 390 too.
SCREW IT - just get a 3-keyway aftermarket Cloyes and install it "straight up"
hey if you want a perfect carb for your situation i would recommend a demon 650 its easy as hell to tune and is easy to adapt to alterations for your engine .as for the intake to make the most of it check to see what your heads are rated for if they are only rated for a 2v application you can still put them on your just not gonna get the fun you would from havin 4v heads good luck
KsCop
02-21-2021 02:19 PM
PLACT88
07-02-2015 04:53 PM
hooziewhatsit
05-11-2014 06:56 AM
