Pulsating When Braking
Old Apr 19, 2010 | 07:57 PM
  #31
03-6L-X's Avatar
03-6L-X
Originally Posted by BAJI26
Finally got the brakes where it was when I first installed the Powerslot Cryo Rotors.... I got then resurfaced and now it feels sooo smooth.
Next problem is the ball joints, how difficult it is to change them and what tools do I need?
Both upper and lower need to be changed!
Where can I get the best priced Moog with the nipples?
Thanks!
Take a look at the dynatrac ball joints. If they go bad you can rebuild them.
www.dynatrac.com
They are going to cost you way more money $599.00, but have heard they are solid as the rock of Gibralter.
I spoke with Dan at extension 216.
Even though some like the moog with lifetime warranty, the RR time and money is not covered. JMHO
Old May 17, 2010 | 09:13 AM
  #32
BAJI26's Avatar
BAJI26
Originally Posted by DSMMH
Be sure the lug nuts are torqued evenly and to the proper torque. I torque mine to 165 lbs-ft per the Ford maintenance manual in three increments: 50 lbs-ft, 100 lbs-ft and 165 lbs-ft. Also, make sure there is no rust accumulation between the hub and rotor. When I put my DAB rotors on, I sandblasted the hub area where the rotor makes contact.
DSMMH
I torque mine to 150lbs always!
www.dynatrac.com
Dem too expensive and if I maintain the moogs it should last awhile. Plus I did and will always do the balljoints myself cause they are so easy to replace!
Old Apr 23, 2011 | 12:32 AM
  #33
rdebinski1's Avatar
rdebinski1
I got at least 165K miles out of my original rotors!!! why can' they sell us something that is of the same quality? that' s what i want to ask ford. Maybe there is some kind of manufacturing defect and/or specification problem with the manufacturing specs for these after market (non Motrocraft) rotors????... frustrating!!!
F35ott
Jan 1, 2017 10:26 AM
Jansarchie
All Things Towing
17
Oct 7, 2016 03:43 PM
erniek70
Mar 14, 2016 05:54 PM
THEDON117
Mar 24, 2009 12:08 AM
viperbluelx
Aug 25, 2008 10:36 PM
