Engine Removal Guide?
Old Feb 22, 2010 | 06:03 PM
RIKIL's Avatar
RIKIL
Is there such a thing as a guide that I can get that would let me know the steps to removing an engine? I am not sure if there is an order to removing things that would be best or if there any 'hidden' bolts or tricks for getting at things. That's all I was looking for.
Going to be doing this to a 351W, not sure what tranny it will be connected to or what it will be coming out of (92-96 F series or Bronco I am guessing). Going to the local pick-your-part place.
Thanks
Old Feb 22, 2010 | 07:29 PM
pete17c's Avatar
pete17c
a Chiltons or Haynes manual is not 100% (things like "disconnect all remaining wires"), but they are a good place to start ..
Old Feb 22, 2010 | 07:32 PM
Conanski's Avatar
Conanski
Here's a quick guide from memory.
Remove all cables and hoses from the upper intake.
Disconnect the EGR line at the valve and the support bracket on the passenger side.
Remove the 6 bolts attaching the upper to the lower including the hidden Torx bolt at the center pass side.
Remove the upper and lay it asside.
Now disconnect all remaining wiring from sensors, injectors, and grounds and lay it asside. Don't forget the big ground from the battery to the block on the front pass side.
Remove the fan shrowd and fan.
Disconnect the exhaust near the manifolds with a sawsall if allowed, hacksaw if not.
Remove the 4 bolts from the engine mounts at the block.
Disconnect and remove the starter.
Remove the 2 bolts from the trans flywheel cover and then the 4 nuts attaching the flexplate and torque converter.
Remove 6 bolts attaching the bellhousing to the motor.
Attach a hoist and take the weight on the motor off the mounts, Grab the motor and shake/wiggle it side to side while somebody else pulls the hoist forward, this will dislodge it from the dowels in the trans bellhousing. once it's free twist it in the engine bay and hoist it out.
Old Feb 22, 2010 | 08:00 PM
quicklook2's Avatar
quicklook2
good list, you forgot:
open hood, if closed
remove battery, if connected to test engine
drain fluids
mark wires, vacuum gauges as needed
Old Feb 22, 2010 | 09:58 PM
fishforlife2007's Avatar
fishforlife2007
and last but not least....bring beer and buddies to help. wait, that should prolly be first...
Old Feb 23, 2010 | 09:09 AM
RIKIL's Avatar
RIKIL
OK, just one question...
When you say:
What is 'the upper' that you are referring to? Are you talking about the intake manifold?
Thanks
Old Feb 23, 2010 | 11:16 AM
Prozon's Avatar
Prozon
Just a few comments to make here. Looks good otherwise.
The EGR is all on the engine itself, correct? Intake to Manifold. Why remove it?
The upper to the lower...? What are you talking about?
I believe there are eight bolts. Two on bottom, four on sides, two on top. Starter must also be removed.
To get to all of the torque converter bolts you must turn the engine over, I suggest a socket on the pulley.
Removing the radiator free's up a lot of room. I suggest doing this when removing shroud/fan.
Don't cut your exhuast?! UNBOLT IT. Unbolt the pipe from the manifold.
Hop under the truck and they will be easy to see.
Pulling it ahead a little should allow it to come free of the tranny easily. And twisting the engine in the bay isn't needed...
Also, draining all the oil and coolant is recommended. Hope it helps.
Old Feb 23, 2010 | 12:58 PM
nstueve's Avatar
nstueve
the upper Conanski is refering to is the plenum or the big aluminum piece that says "Ford Fuel Injection" or "Ford EFI." Sometimes reads 5.8 Ford Fuel Injection on newer trucks. on the top of the engine (commonly refered to as the "upper manifold"). on the 351w there 6 bolts. 3 are in plane sight on the dirvers side of the plenum and the other three are 2 inches to the left kinda under the plenum. there are holes in the plenum at the right spots to get to theses.
In any case i just pulled my first motor and I have a great suggestion for you.
Find some card board, use a utility knife to cut "X's" int he cardboard in the pattern of the bolts as they are found on the engine. Label each piece of cardboard with the motor piece they came from (ie: valve cover, water pump, heads, exhaust manifold... etc.) this will keep you organized and won't take to long to organized "groups" of bolts... I did this and found it EXTREAMLY helpful during rebuild. Also Duct Tape and a Sharpie is the best idea to label the wires as they come off (I used masking tape and it faded and fell off after a while...)
Old Feb 23, 2010 | 11:10 PM
Prozon's Avatar
Prozon
I suggest masking tape and a sharpie to label any wires on the truck that you will need to attach. Easiest if you label both ends the same way.
Put one on the distributor plug and write "distributor" then on the wires do the same and write "distributor", so there's no guesswork installing them.
The first few motor swaps I did, I just kind of piles bolts around, sometimes I put them on cardboard and labeled them. (Its all good till your foot kicks the cardboard and you lose all the bolts!!) I think the BEST solution for bolts when you do an engine removal is to invest in a sharpie (permanent marker) and a box of zip lock bags. You can write down on the bag what is inside, and there's plenty of bags for everything.
If you have any questions, just ask.
Old Feb 24, 2010 | 08:10 AM
nstueve's Avatar
nstueve
I was more suggesting that you cut the "X" in the card board so you can push the bolts into the card board... keeps them together and in the same pattern they came off in. But to each his own...
I also use a sharpie and perminent marker but I use a numbering system. IE: I use 2 "1's" to mark where a wire goes together. the next one 2 "2's" and on and on... this way by the time i get done I know i have XYZ number of wires to reconnect and can use a check off or count down to get them all hooked back up...
Old Feb 24, 2010 | 10:30 AM
andym's Avatar
andym
Prozon, please learn how to use the quote feature. It's impossible to quote your replies and address them the way you have done it.
There are 6 bolts holding the trans to the motor.
Cutting the exhaust piping behind the manifold is fine if the truck he's swapping into already has an exhaust. The point is to try and pull the motor out before the yard closes and stubborn, rusty exhaust bolts are a major slowdown.
If he doesn't know that you have to crank the motor over to get to all the torque converter bolts then he probably shouldn't be pulling an engine.
Old Feb 24, 2010 | 11:01 AM
Prozon's Avatar
Prozon
I am well aware how to use the quote feature. I had computer issues and it took me long enough to post the reply as it is. If you really wanted to quote me you could have copied and pasted it and just type "[Quote", which is what I had to do for most of that reply anyways.
However, as he is asking how to remove the engine, I assume he has never done it, so I thought I would give him all the advise he might use. Its not like he can have too much information about how to pull an engine. Sound good?
And as for the transmission, I guess I was mistaken. I was thinking the engine was mated to a C6 transmission, in that case, a C6 would have eight bolts.
With the exhaust, well it could go either way, you might actually need the exhaust so cutting it may not be a good idea. I agree that it may be easier and faster if you have a complete exhaust and do not need any of it, but he stated nothing to make me believe he had an exhaust system, so naturally I assumed.
Old Feb 24, 2010 | 11:04 AM
andym's Avatar
andym
It doesn't look like it to me.
Its not like he can have TOO MUCH INFORMATION about how to pull an engine, so don't be a dick when i'm just trying to be helpful. SOUND GOOD?
Ok, fair enough. However, be mindful of the guidelines, especially when calling another user a dick.
That is just nonsense. All 351w's have the same bellhousing pattern - six bolts - regardless of what transmission is behind the motor.
Old Feb 24, 2010 | 11:21 AM
Conanski's Avatar
Conanski
No.. it connects to the passenger exhaust manifold on the 5.8 and needs to come off to get the upper intake off.
I'm talking about the intake, have you never seen an EFI truck motor? The upper has to come off so the wiring can be disconnected. This also makes it easier to get at the bellhousing bolts and smog tubes at the back of the motor.
No only six on the SBF bellhousing, the bottom two are just in the TC cover which is bolted directly to the trans.
Yes that's right.
Yep, the rad may already be gone on a scrapyard vehicle though.
Not on the scrapyard motor unless you want to keep the Y-pipe, these bolts won't likely come off easily so don't waste your time.
Old Feb 24, 2010 | 01:57 PM
Prozon's Avatar
Prozon
I was thinking of a 460 removal in my head. Sorry for that.
On a 460, none of the intake has to come off, and the EGR can stay connected aswell because the manifold and the intake can stay intact.
As for a 460 and a C6, there are eight bolts. Which is why I had said it.
Sorry for having my mindset on a 460. Now I feel stupid lol.
Anyways i've got a good rule of thumb for removing any engine;
Just keep unplugging stuff until nothing is attached to the truck.
