Sponsored by: Auxito
intrument panel is dead
Old Feb 21, 2010 | 12:12 PM
Pbear74's Avatar
Pbear74
4wd Low
I have a 97 F-150 4.6L V8.
The other day I noticed that the instrument panel is dead, the odometer is not even working. I changed the relay for the instrument panel in the fuse box inside the truck but that made no difference. What else could be causing this?
Thanks
Old Feb 21, 2010 | 12:52 PM
projectSHO89's Avatar
projectSHO89
Check the fuses that run the cluster.
Old Feb 21, 2010 | 01:10 PM
Pbear74's Avatar
Pbear74
4wd Low
which ones are those?
Old Feb 21, 2010 | 07:43 PM
projectSHO89
See owner's manual...
Old Mar 1, 2010 | 01:00 AM
Pbear74's Avatar
Pbear74
4wd Low
ok, so i found the fuse(#29) that was causing it and i replaced it.
But then, it went out a day later.
What's that all about?
Old Mar 1, 2010 | 06:45 AM
darkmage55's Avatar
darkmage55
short somewhere?
Old Mar 1, 2010 | 06:48 AM
projectSHO89
Wiring harness is chafed where it exits the shift lever's tube.
Pull the column shrouds and repair.
Common repair.
Old Mar 1, 2010 | 09:53 AM
Pbear74's Avatar
Pbear74
4wd Low
Common repair.
Any instructions laying around here for this fix?
I'm pretty green when it comes to this stuff.
Thanks guys.
Old Mar 5, 2010 | 01:32 PM
Pbear74's Avatar
Pbear74
4wd Low
So i took this thing apart yesterday and was looking everywhere for this chafed wire but I could not locate it.
I'm wondering if I pulled off the correct parts because I couldn't see any "shift lever tube". I pulled off the bottom panel that covers the fuse box and top cover over the steering column.
Are the column shrouds the actual black covers that cover the steering column? The ones where the key goes?
oh by the way, during this adventure I went ahead an pulled the instrument cluster and replaced the bulbs.
harleyhal
Oct 10, 2023 11:49 AM
Villagemonkey
Electrical Systems/Wiring
Nov 7, 2004 01:41 PM
Wstrombe
Sep 21, 2002 05:52 PM
DWalker
Feb 28, 2002 02:38 PM
