Tempature Gauge
Old Feb 21, 2010 | 03:55 AM
sctrt's Avatar
sctrt
Tempature Gauge
How do I test my tempature gauge to see if it is good or not?
1985, f150, 2wd. 302, EFI.
Thanks.
SCTRT
Old Feb 21, 2010 | 04:13 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Unplug the temperature sensor under the hood of the truck, and ground that wire out with the ignition switch in the run position.
If the gauge is good, the gauge will swing over to hot.
Don't leave the gauge wire grounded for excessive periods as it can damage the gauge.
Old Feb 21, 2010 | 06:35 AM
ri_truck_guy's Avatar
ri_truck_guy
Just keep in mind that this test will only tell you that the gauge works. It won't tell you why it doesn't work. Don't automatically replace the gauge if it doesn't swing to hot. There's a lot of wires and connections to check it if doesn't swing.
Old Feb 21, 2010 | 01:19 PM
sctrt's Avatar
sctrt
Thanks, I will try this in the next day or two.
sctrt
sctrt
Jan 27, 2013 07:14 PM
sctrt
Apr 17, 2009 01:53 PM
sctrt
Apr 14, 2008 08:57 PM
sctrt
Apr 9, 2008 05:54 AM
sctrt
Apr 7, 2008 10:07 PM
