Accessory drives
Old Feb 20, 2010 | 02:23 PM
vwbill's Avatar
vwbill
Accessory drives
I have a ‘86 F150 4x4 with 302 (5.0) engine. Would like to upgrade the "V" belts to serpentine drive keeping air pump, alternator, power steering and A/C compressor. Water pump was recently replaced and would like to reuse if possible. Search found an interchange of front covers. Does anything like that exist for brackets? Are there any guides as to what is needed?
William
Old Feb 20, 2010 | 02:24 PM
Redneck1465's Avatar
Redneck1465
Um not sure how you did this but you might want to repost this as it is quite difficult to read.
Old Feb 20, 2010 | 06:14 PM
86bigred's Avatar
86bigred
first off if you go the serpentine setup you will have to replace the water pump with a reverse rotation pump.secondly you should be able to find what you need from a wrecker.i had a system from an late 80's mustang.
Old Feb 20, 2010 | 06:31 PM
vwbill's Avatar
vwbill
Accessory drives
Ok, I’ll try rewording. I want to swap to a serpentine belt system. I’ll need reverse rotation water pump, different timing chain cover and brackets. Will my alternator, power steering pump, a/c compressor and air pump mount to these brackets or do they also need changed? I’m in the planning stages of the swap and not sure what to look for.
Old Feb 20, 2010 | 06:41 PM
86bigred's Avatar
86bigred
i don't think you will have to change the timing cover(someone will correct me if i'm wrong).i'm pretty sure all your accessory's will work you will have to change the pulley's.might be easier to grab the accessory's with all the brackets at a wrecker.i did this like 12 years ago and trying to remember all this.
Old Feb 20, 2010 | 08:06 PM
ri_truck_guy's Avatar
ri_truck_guy
I've done the swap. I used the bracket setup off an 88 truck. You do not need a new timing cover, You will a new water pump. The power steering pump, AIR pump, and alternator will all fit. They just require a pulley change. The AC compressor is different. You'll also need new AC hoses. I've read the setup from 86-93 Mustangs will fit a truck. I can tell you from experience the 95-96 Mustang setup will not work.
Old Feb 20, 2010 | 08:55 PM
Franklin2's Avatar
Franklin2
You will also need a new fan, since it runs in reverse.
Old Feb 20, 2010 | 08:57 PM
ri_truck_guy
Thanks Dave....I had already done the e-fan conversion, so didn't have to deal with that....
Old Feb 21, 2010 | 08:43 AM
Terpfords's Avatar
Terpfords
Technically the timing covers are designed for the different water pumps, so there is a difference. Timing covers are expensive or hard to come by at times. I had a v belt cover on my mustang for some time and was racing it, it worried me to death, but the car ran fine.
Old Feb 21, 2010 | 10:11 AM
vwbill's Avatar
vwbill
Thanks guys, that is what I was looking for. This is the first Ford I want to modify and I was confused on what needed changed. Searched the Internet and only found write-ups on aftermarket conversions that left off one or more items.
Old Feb 21, 2010 | 02:48 PM
Terpfords's Avatar
Terpfords
To clarify, you can put a newer reverse rotation water pump on a older timing cover for a standard rotation/v-belt water pump.
Old Feb 21, 2010 | 03:21 PM
ri_truck_guy
BTW, since "cash for clunkers" timing covers are a dime a dozen in boneyards. Idiots.
William Tunnell
1997 - 2003 F150
Sep 16, 2015 01:11 PM
brutus67
Apr 22, 2015 11:27 PM
85redevil
Jan 23, 2014 01:06 AM
Neon Williams
18
Jan 14, 2013 07:42 AM
sled250
Apr 13, 2012 10:00 AM
