Sponsored by: Real Truck
V10 Coolant Temperature Sensor Location?
Old Feb 20, 2010 | 09:30 PM
suprdutyv10's Avatar
suprdutyv10
Hello,
I’m having a problem with my 1999 F250 with the 6.8 V10, During cold starts, it starts and immediately stalls 2-4 times (depending on outside air temp, warmer = less stalls) before it starts and runs. Using a scanner I found the coolant temp sensor to be reading about 3 volts when it should be reading about .5 volts at 190 deg. I found a sensor near the thermostat but it seems to be only for the instrument temp gauge, does anybody know where the engine coolant temperature sensor that controls the computer is located? Does the computer pick up coolant temp from a different sensor?
Thanks
Old Apr 29, 2017 | 12:46 PM
jfrdallas's Avatar
jfrdallas
Temperature Sending Unit Response?
Hi, just wondering if you ever received a response to your question? I have a motorhome with a 6.8L Ford V-10 Chassis. Are there TWO sensors, then or just the one?
Thanks for your help.
Jim
Old May 29, 2023 | 09:55 AM
carpe_diem's Avatar
carpe_diem
Have the same question. My 2012 V10 has terrible cold starts. Long crank, no start. But starts when it's warm.
Old May 29, 2023 | 02:18 PM
WWR's Avatar
WWR
I think in '12 they just used the CHT (cylinder head temp sensor). Common failure on the 3V 5.4, but it just causes the gauge to peg and limp mode. I haven't heard of it affecting starting. It reads cylinder head temp but doesn't actually touch coolant at all.
jesse5
Jul 4, 2014 03:35 AM
cutlass
Jun 27, 2013 06:21 AM
savage250
Feb 1, 2012 10:43 AM
