Isn't the Internet great?
For misinformation that is.
CA emission test on older diesels does not include tailpipe probe.
Than I don't see scanner plugged on this test.
TOTAL BS.
He didn't check how active is Bay Area Police in tracking residents driving with improper registration. The penalties go in big hundreds and all it takes is an upset neighbor, or Police ride on employees parking lot. The state will get its money this way, or the other.
I wonder if his insurance rate changed with the address?
I got my truck registered for this year and didn't have to go for the inspection. Suppose it is every other year. Not that I worry about it much. My truck is all stock and come with no foil from the factory.
I dunno. It's been registered to a Texas address for two years...
Im moving to cali here soon. However im fortunate to keep my Oregon registration. However the Bases require a emmisions check to recieve a base sticker. I might just take the temp passes from now on LOL because I know if they look at my intake they will flag it. However i might turn up the chip just for Chits and Giggles to see the bay fill up with soot LOL
You have to remove the tuner completely otherwise it fails the visual test. The CCV is simple. It just comes off the driverside valve cover and should enter your intake track between the turbo and airfilter.
IIRC, I just have to reverse the doghouse and mauybe buy some new hosing.
ugh, i remember install the tuner, that bolt is a PITA to get to
If you hide the unit and the wire it would work. But if they find it then you fail.
Someone mentioned having the 0 position programmed for a "stock" setup for single shots rather than no start. Not sure if it would operate properly, but if you unplugged the control at the chip. Then you could have the chip installed without the wire exiting the PCM. Might ask Jody.
