Alcoas
Old Feb 20, 2010 | 08:29 AM
ADTMan's Avatar
ADTMan
Alcoas
Sycostang, I like your alcoas on your truck.
I have a found a set of alcoas off of a 96 F350 2wd dually. I was wondering if those would fit my 4wd chevy dually, it is an 05. I am trading this guy for them. I am giving him some woodworking tools that I got from a pawn shop. He has been trying to get these saws, drills from me for some time now. He is the one that told me he would trade me for the alcoas. I figured I will trade just for resale value or use on the 95 if I can get it going. But I would prefer to put them on the 05. Is there someplace I can look on the wheels for part numbers to reference an alcoa website? These are complete wheels with caps.
Old Feb 20, 2010 | 12:14 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Watch the center opening diameter.
From memory the Chevy wheels are slightly smaller that Ford and Dodge uses, but I have also read where members have dressed the opening diameter and made them work.
Old Feb 20, 2010 | 01:06 PM
ADTMan's Avatar
ADTMan
Coolie, my only concern then is hauling the stuff I haul. Are these wheels going to be able to handle 12K lbs on a gooseneck or bumper pull trailer? I sure would hate to warp them or ruin them. I would rather sell them if that is the case.
Old Feb 20, 2010 | 01:09 PM
johnboggs21's Avatar
johnboggs21
They have alcoas on semis, so they must be pretty good for weight.
Old Feb 20, 2010 | 06:26 PM
Sycostang67's Avatar
Sycostang67
Alcoas should be aftermarket(they aren't hubcentric like OEM ford wheels anyway) and should fit on your chevy. It's usually the OEM chevy or dodge wheels that wont fit the fords anyhow, so a ford wheel should fit a chevy. I would certainly try swapping them onto your truck before finalizing a deal. I almost called off my trade after the alcoas had been mounted on my truck when I heard I might not be able to use the center caps I wanted.
Old Feb 21, 2010 | 12:34 AM
ADTMan's Avatar
ADTMan
Well Sycostang I must compliment you on your truck. It is absolutely gorgeous. I will try the wheels before I make the trade. Thanks for the input.
Old Feb 21, 2010 | 09:31 PM
87crewdually's Avatar
87crewdually
Alcoas for a F-350 dually certainly are hubcentric. Had my dad's off today for a flat repair and I know his lug nuts are the same as mine with the built in washer and the wheels are centered by the hubs. And yes they are Alcoas because they still have the sticker on them. This may not be the case for your little single wheel but, the original post said dually.
ADTMAN if they don't work out for you I've been looking for a set. (2 rears and 2 fronts)
Old Feb 21, 2010 | 10:26 PM
Sycostang67
Thats weird, learn something new every day. My SRW Alcoas are not hubcentric, most aftermarket wheels aren't...in the SRW category anyhow. Since ford still seems to have the largest hub diameter of the big 3 I still think they should fit a chevy.
Old Feb 21, 2010 | 10:55 PM
starmilt's Avatar
starmilt
I'm not sure on the new ones, but my alcoas was chevy or something, I had a machine shop fix them to where they would center on mine.
Old Feb 22, 2010 | 01:00 AM
ADTMan's Avatar
ADTMan
Thanks for the info guys. I really appreciate the help. Star, I am sure a good machine shop can take care of it for me if I decide to go that far. Never thought about having them machined. Thanks for the idea.
If they don't fit my chevy I will let you know. They are coming off of a 96 ford 2wd dually. Should fit your 87 w/o any problems I would summize. I will let you know.
Schvwartzeboy
Dec 4, 2025 03:07 PM
uniwagon
Feb 27, 2015 09:43 AM
lance65
Dec 25, 2013 09:13 AM
ChaseTruck754
Dec 14, 2007 02:02 PM
truckdog62563
Jul 28, 2006 06:20 PM
