Ok, I had an auto electrician fit relays to my headlights to relieve the switch and it's issues...but, now I have another problem....when I turn the lights on, to park, the low beam comes on, and so do both indicator arrows in the dash display....after a few minutes, they indicator arrows go off, and the truck drops to park. If I put the lights directly onto low beam, then high beam comes on too....regardless of the dip switch position...and the indicator lights too.....any ideas, any idea of a fix...I will be taking it back to the electrician, as I am not happy...but if anyone has any tips, let's have 'em!!
They were working fine before it went in, apart from the "usual" flashing/cutting in and out.
Truck is a 1977 F150 Ranger XLT.
Thanks,
Shane
You would hate London!! There is a lot more to see and do here in NZ....
i know I would, I want to see New Zealand, a friend of mine took a trip there, the pics were REDICULOUS, I cried, cause i know i'll be closer to death before I see it, if at all.
i am new here and was wondering the advantage to putting these relays in
The advantage is the old wiring in these vehicles was designed to power the old style headlights and with the newer style halogen bulbs installed the current draw is almost beyond the capacity of the wiring. You lose brightness with the newer bulbs. Installing the relays allows for the old wiring to be used only as a trigger for the relays and you get brighter headlights. I acquired a harness, pre-made, and installed it in my truck some years ago and have been pleased with the results. I had heard some bad stories about the relays burning out in this harness so I went out and purchased a couple of replacements and put them in my 'go' box just in case. Never have needed them yet. Here is a link to the harness I used, plug and play. LMC Truck Parts - Page 137
Even if you use the old headlights, the advantage is you take the amp draw off the headlight switch which is the weak link in the system and especially if you pull a trailer (extra lights) they burn up and even over heat the harness connector. This eliminates this problem.
The other advantage even with stock lights they are brighter because they get full battery voltage instead of loosing voltage from the lenght and smallwires for the headlight system that is stock.
Well, looks like it is sorted, the sparky tracked it to a faulty earth in the dash wiring....it only takes a sniff of power to trigger a relay.....so there ya have it, the old wiring was causing the issue!!
I agree with the above comments, it is well worth getting the headlights relayed, they are far brighter, and it protecs the trucks wiring and switch too
Shane
or if you have as much time on your hands as I do, build your own harness set, I'm in the process of doing just that.
